This is the DJB version, as you described it!I also reached out to Paul Bailey about David's mega-inertia wagon purely because i was interested in the design but it sounds as though that has long since gone. I still have a picture of it - belt driven dual flywheels from articulated bogies, one flywheel had a fan and it required a strong engine to pull it
Hm but you try shunting with a Roundhouse without a SloMo, pretty near impossible.Smoly Hoke!!!!! Me, I just drive my steam locos slower. Hauling THAT behind any of my locos would have me reaching for the eye bleach post haste.
Ok Roundhouse Puffer, not sure you would invest a lot of dosh on a SloMo for a RH dismal.Well, actually, I can shunt perfectly with my one and only Roundhouse loco - it's a battery r/c 'Harlech Castle'.![]()
That is also my thoughts about my Russell that is a very untamed beast, but I know that a SloMo will tame it. Just need to get my act together and order another one.I have considered ripping all that dangerous gas, and flame, and steam under pressure, out of one of these...
Then fitting an electric motor, and a pile of Lithium batteries!So much safer..
10-15psi, gas turned w-a-y down ... opinion is divided.Hm but you try shunting with a Roundhouse without a SloMo, pretty near impossible.
Hm but it still runs away uncontrolled even on a simple run between stations. Needs a serious look at and a SloMo.10-15psi, gas turned w-a-y down ... opinion is divided.
In all seriousness I think the regulator arm is rubbing against the poker and this is not helping, another of those round to it jobs that are less interesting then Battery Conversions.? Heavy water ? - Bit of weight, to slow it down, perhaps?![]()
