Madman
Tramcar Trev said:stainless steel is fairly corrosion resistant, if you can find bronze hinges let me know... You can buy loose pin brass hinges so that the pin can be pulled completely...
http://www.ebay.com.au/itm/Quality-Door-Butt-Hinge-SSH70-L-70x50x1-6mm-Loose-Pin-Stainless-Steel-/271278305073?pt=AU_Building_Materials&hash=item3f29726f31
If you are prepared to spend alittle more, go to a builder's hardware supplier. Pretty much anything is available. It so happens that I was looking for more solid brass barrel bolts for use as turnout controls. I found a whole bunch of marine hardware, which is solid brass plated with chrome or nickel. As I mentioned in another post, I am a carpenter and in my forty plus years in the trade, I installed an amazing array of hardware on doors. We relied on a couple of very knowledgeable hardware suppliers. Whenever we hit a roadblock, they would come to the rescue with stuff I didn't know existed.
