The main weed that causes me trouble is creeping oxalis, it looks a bit like clover. It's a noxious pest here, nearly impossible to eradicate without a scorched earth policy. Lucky it's seasonal, so it will all die in a couple of months.
Sure thing!![]()
The design was very approximately based on the LGB track cleaning loco, with a few (actually a lot) of concessions to make use of available materials. I'm lazy too, but also poor and cheap so sometimes home made is the only option. It fits with the theme of a perpetually impoverished and run down tramway anyway.
Just to show there is some sort of weed control on the tramway, here is the environmental contractors engaged in their duties.
Thanks again for the info. Love the vid with the chickens; it obviously doesn't worry them, but I'm sure the one in the foreground was eyeing it up as possibly edible!
Just the other day, I was talking with my wife about getting some chickens. She had mentioned that they love to eat Ticks. It seems the Ticks are in abundance this year. The only issue is that we don't have a fenced in yard, so the chickens might want to roam off. I recall many years ago, when I lived in Philadelphia, a gas station owner had ducks living on the grass strip between his gas station and the Roosevelt Boulevard. The grass strip is about ten feet wide, and the ducks never strayed off it. It was something to see as you drove by on the Boulevard, which is a 12 lane tree lined thoroughfare in North East Philly.
Have a look here;
http://www.all-battery.com/148vli-iobbatterypacksandmodules.aspx
I have some of the blue Chinese Li-on batteries. While they perform reasonably well, they are not as robust and trouble free as these regular Li-on batteries.
The Goons having been mentioned.. My mind drifting to the late-great Michael Bentyne(sp?) (of potty-time fame)..
The above looks like the laptop is powered from so strange contraption sitting above the fire!
The last tram of the evening departs soon. Don't miss it!
There's always a sense of poignancy when the last tram of the day departs!
Thinking about how your part of the world takes pollution, I will not give my usuall suggestion of Soaking Wood in old Engine Oil to preserve it. However rather than Painting the bottom, perhaps letting the posts sit in the Paint Pot for a day or two would allow the Paint to get well impregnated into the Wood. Of course you would need to let them thoroughly Dry Out before Placing as replacements for rotten ones. I would have thought that a good old cheepo Oil Based Paint should do the trick.The wet winter has been taking its toll on the tramway infrastructure. I had to replace another overhead wire pole the other day that had rotted through at the base. The replacements are painted on the end that goes in the ground, hopefully they'll last a bit longer.
Not sure how you Plant the posts, but what might work well is to have some Tube in the Ground perhaps some 6 or so inches longer than the Posts.,Cemented in with an area of Gravel for Drainage beneath would allow any Dampness to drain away. Then you would just need a bit of Brass or Copper Wire say old Mains Wire Stripped, passed through the pole with some spare either side to keep the pole at the desired height.
I find it best to plant the narrow end into the ground as often the other way does not always provide enough height... just a thought..
Hey mate are you actually from Eltham? if you are i might only be a short trip away! We usually treat posts with bitumen thinned out a bit when doing a bit of fencing as opposed to the engine oil which seems to work well and would allow you to keep the wooden posts?
cheers
Jake
