Just make a double strip of tiles mate, but score the centre line rather than cutting right through.Steve said:Mel ,
How have you done the ridge tile please ?
Does that make sense?
The barge boards like these mate?Steve said:Yes thanks ,
I have not scored through at all just used a chisel to make an indent .
Also Mel , could you please take a pic of the gable where the wood is under the tile .(i think this is what its called)![]()
jameshilton said:I've got my hands on some felt for my shed roof too - your's looks the business! The doors look quite thick though? What are you using for windows? Does the kit come with some?
Steve said:The strips are cut at the width of my 24" 600mm Steel rule the individual tiles are cut to the width of my 6" 150mm steel rule.![]()
trammayo said:Steve said:The strips are cut at the width of my 24" 600mm Steel rule the individual tiles are cut to the width of my 6" 150mm steel rule.![]()
10 out of 10 for that answer I'm sure![]()
Couldn't you use your 6 to measure the 24 and the 24 to measure your 6?
Mick
Steve said:trammayo said:Steve said:The strips are cut at the width of my 24" 600mm Steel rule the individual tiles are cut to the width of my 6" 150mm steel rule.![]()
Mick
Dont be stupid use a 6 to measure a 24 that would take 4 times as long![]()
