Fallowfield Road goods shed
Chris Vernell
Tortoise
1,843
77
Nepean, ON
Canada
I put the Thorley Miniatures goods shed aside for months while I attended to other things, but I have taken it up again in hope of having it ready for 2023 train season :blush:.
I decided I wanted to make the truck loading door a slider rather than the kit's hinged doors ...
... which I had to trim to fit the opening and overdid it :oops: -- and I had to use the hinges for the crossing gates because I lost the hinges in the TM gate kit :oops: ...
... so I found a 3D sliding door file online, made the door a bit wider and taller and the rail longer, and printed it.
I've a few more guides and such to cut and place, and paint to spray on our next dry day, but I think it will work.
I plan to make an awning to go over the door as another part of making my shed look a bit different to the standard kit.
Once I have finished with the interior, I can fit the roof joists and the roof itself.
Chris Vernell
Tortoise
1,843
77
Nepean, ON
Canada
I also screwed up my courage to hinge the track doors -- although I see my hands were still shaking when I took the pic o_O
I bought 1/8" 00-90 hexhead screws to replace the pins supplied in the kit, along with appropriate digital drill bits (you twist them with your fingers). To my surprise, I think I managed to get it right.
And then I realized that the doors as supplied won't clear LGB track :oops:
A clearer view.
So, either I leave the doors open, or employ the Dremel cutting disc to trim the bottom of the doors. Option #2 is more likely. When my hands aren't shaking.
And yes, I shall paint the hinges.
5,009
76
A clearer view.
Or you could put a base on the shed using perhaps Plastic Covered Foam board and paint to match the sides, look like a base of some sort.
JimmyB
23 Feb 2018
7,000
929
70
Weston-super-Mare
www.tumble-down-falls.co.uk
Yes, or as a concrete or brick base just under the walls expanding outwards should do the job.
Chris Vernell
Tortoise
1,843
77
Nepean, ON
Canada
Yes, I did think of that, but it would raise the loading dock too high for the wagons :worried:
3,553
I reckon a railway would just hack a rectangular lump out of each door?
Perhaps, with a crude hinged flap, they could drop down, to keep the worst of the weather out?
Chris Vernell
Tortoise
1,843
77
Nepean, ON
Canada
While the washing machine was doing the work, I cut a skylight opening in the goods she roof over the loading dock. Now I have to find clear material to fill it; I know I have it somewhere.
Chris Vernell
Tortoise
1,843
77
Nepean, ON
Canada
Framed in the skylight. Will rattle-can it before installing “glass”.
Messrs Rhino and Madman will probably be professionally appalled, but my clumsy fingers don’t do fine motor skills.
1,715
Looks good to me
Chris Vernell
Tortoise
1,843
77
Nepean, ON
Canada
Spritzed, will need touchups later
Chris Vernell
Tortoise
1,843
77
Nepean, ON
Canada
Half the roof in place:
I will wait for the adhesive to cure before installing the other half.
Which has had the skylight “glazed”:
Chris Vernell
Tortoise
1,843
77
Nepean, ON
Canada
Second slab of roof glued in place.
Skylight nice and clear — until the pigeons land.
Chris Vernell
Tortoise
1,843
77
Nepean, ON
Canada
She’s finally in place:
After the trouble I took to cut out the bottom edge of the doors to clear the track, I found that what works on a nice flat workbench is not enough outdoors where the siding is raised on the edge of a cupped plank. :banghead:
Oh well, I can raise the whole thing about 4 mm, or I can simply leave the doors open
Reactions: 1 users
