Another update again.....
Shed with a door to stop the local wildlife. This door is on a pull system too, so it's very easy to pull up and down.
Just checking if the trains would be able to fit through (which they couldn't), so needed to take some stuff away from the white wall.
Once I'd taken a chunk out of the wall (I still need to tidy it up - but desperate to get some trains running). Then I laid the concrete to support the track. The door has had a its first coat of paint too.
Running past the wall, which I need to scrape the concrete off the sleepers to tidy them up too.
Running behind the BBQ which is what my neighbour can see (they are as good as gold and love the railway). I needed to lay the 2 levels of bricks too, to get it to the right height.
How it connects up to the track.
The door with a couple of coats of paint. The track is now linked and the train has somewhere to sleep at night.
The next step was for me to come up with some lights for the main station. I thought I would do this using copper plumbing piping. This is simply a 10mm T joint with 2 10mm end joints.
This is a 15mm to 10mm conversion joint which gives it more visual interest. I have since added a second 15mm joint to make it a bit taller.
One of the finished poles in the mold I inserted in the concrete.
After tidying the excess led, I painted them and this is the finished product. Far cheaper that the LGB ones, just need to run the cables now.
