chris beckett said:Repeating myself - brilliant!!! Q? Do you make your own windows and doors? Or buy them in?
Thank you Chris. Appreciate it
Monk_1987 said:Ye it is all made up from UPVC plastic board. I got it from http://www.signforce.co.uk/Signforce/Forex_Classic.html It is the stuff they use on outdoor signs and I have been assured it is good to use outdoors.
The main structure is made out of 6mm board. The roof and window sills etc is made out of 3 mm board and the roof tiles and corner stones are all made out of 1mm board! Then the join on the top of the roof is a 10mm plastic pipe cut in half.
The glue I used is Evo Stik outdoor plastic glue... http://www.toolstation.com/shop/p58347?utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&mkwid=0HBUko2B&pcrid=46334903183&gclid=CIiv74iggsQCFRHHtAodLykA9w
No problem with the questions... Without sounding cheesy, this forum has helped me no end with hints tips and ideas so it is the least I can do!
Jeremy Viewing said:Hi brilliant piece of work, can I ask are you using these windows and doors? Jeremy
http://modelshop.co.uk/Shop/Model-Detail/1-24-Scale/Doors-Windows/
chris beckett said:I use drinking straws - from macdonalds - for downpipes!
gregh said:The 6mm x 6mm brass channel you used for the bricks, will be perfect for guttering. Or you can buy styrene channel. For downpipes try straws (as by chris) or thick insulated wire as used for 240V. Here's one of mine
[attachment=0][/attachment]
Just curious - I've used Forex Classic for many years and tend to scribe with a bradawl, which is slow and painful, and so I like the brass rod approach. Nowadays for larger areas of random stone, for example, I do increasingly resort to a Dremmel. However, I find that Forex is so flipping tough, I can barely make a dent if I simply try to press a metallic edge against it - so my question is how hard is 'pushing down hard' and do you have a particular technique to get force on to the rod to make it consistent in depth of indentation? Maybe I am just getting feeble in my dotageMonk_1987 said:I used a set square to scribe a nice straight line, then I would use the left side of the rod in the indent and push down hard on the right side creating the second line. Once I created the original line with the set square it was pretty easy from there on in as each new line became the new guide if that makes sense? I then used a flat head screwdriver to create the vertical line.
ViaEstrecha said:Just curious - I've used Forex Classic for many years and tend to scribe with a bradawl, which is slow and painful, and so I like the brass rod approach. Nowadays for larger areas of random stone, for example, I do increasingly resort to a Dremmel. However, I find that Forex is so flipping tough, I can barely make a dent if I simply try to press a metallic edge against it - so my question is how hard is 'pushing down hard' and do you have a particular technique to get force on to the rod to make it consistent in depth of indentation? Maybe I am just getting feeble in my dotage![]()
There are sheets available commercially, which claim to be outdoor safe, but that's boring! You could do a Google Image search for 'miniature posters', download any that are right for your location and period, then print to your preferred size on label paper. Attach to plasticard before mounting on the building - I usually add a tiny frame at that stage, using profile. A few coats of matt varnish should provide a couple of years protection, or you could cover with a thin layer of clear acrylic or PVC sheet. Alternatively you can print on plain paper and laminate. For more specialised posters, you just need to be a bit more inventive with the searches (and it definitely helps if you aren't modelling a foreign country and aren't much use at speaking its language!).Monk_1987 said:One last question.... What do people do for posters? I want to put some on just to help it along a bit!
