Chris Vernell
45.29 N, 75.75 W
![Canada Country flag](https://gscalecentral.net/misc/flags/shiny/32/Canada.png)
A wee thread drift on to rail lengths is still more or less on topicIn some ways, i can understand why someone might want to depict a more realistic type of rail joint .................... but then we'd be into a discussion about what a prototypical length of rail should be and how frequently they should be spaced![]()
And how many working model gangers one would need to lift such lengths.A wee thread drift on to rail lengths is still more or less on topic![]()
You'd only need 1 ganger but the number of plate layers would depend on the length of rail being movedAnd how many working model gangers one would need to lift such lengths.
Dunno what scale this is.
Blue.View attachment 304240
Since you asked, 39' for American rail. That is so that the rail can fit on the once standard 40' long flat wagon. English, 60' is common, I believe.In some ways, i can understand why someone might want to depict a more realistic type of rail joint .................... but then we'd be into a discussion about what a prototypical length of rail should be and how frequently they should be spaced![]()
Yes but what shade of blue?Blue.
If it is for electric trains thenYes but what shade of blue?
Look's more Caledonian, than BR, to me?Yes but what shade of blue?
Maybe yes, maybe not.... the question is: what's prototypical? From mainline to out-of-the-way short lines, I've seen numerous variations in rail coupling.Huh, far from prototypical.
A lot of room at the termini for the rails to stretch to?Maybe yes, maybe not.... the question is: what's prototypical? From mainline to out-of-the-way short lines, I've seen numerous variations in rail coupling.
Expansion: US mainlines utilize continuous welded rail. How they compensate for expansion is a mystery to me.
Not to me, but, I'm off for a day 'playing trains', I'll explain later when I get home.Expansion: US mainlines utilize continuous welded rail. How they compensate for expansion is a mystery to me.
In the UK with welder rail, according to temperature at time of fitting and the length, a gap is cut in the track, and the track stretched to fit before welding, ends up as a similar principleOf course curves let most of the expansion go, they move.
long straight track is still a wonder to me. Must be laid with enough gap to compensate, but how about 1/4 mile of welded rail?
The answer is at what temperature the rail is laid at (pretty high) and sometimes the rail does have to be cut, shortened and re-welded.
How Do Railroads Deal With Thermal Expansion? | Worldwide Rails
How do railroads deal with thermal expansion? Railroads deal with thermal expansion by heating the rail prior to installation. Therefore, the railworldwiderails.com
That attachment sums up what I've been thinking about how to explain things all day while at a GR meet.Of course curves let most of the expansion go, they move.
True.Yes but what shade of blue?
