Re:My new Freight Depot
.... the granaries have quite a small footprint and are probably only 15 feet to the apex so I decided that instead of building direct lightweight replacements for the two outbuildings, I'd replace the white one with a granary and the "stonework" one with a hen run. Whilst the latter is still on the drawing board, the granary is virtually finished.
It took about six hours over-all - more like waiting for glues to set and paint to dry than anything else. As I had already marked out on the baseboard for the existing buildings (and created paths and roads) then the new structure would not be any larger than the old.
I used foam board again, Cut out four pieces, then the doors and window, then scribed in pencil the stonework as I did the freight depot. The roof is thin corrugated card with Minaco tile/slate sheet stuck on, as per recommendation, with double sided carpet tape.
The outside steps were built up with foam and the step faces and treads covered in masking tape to hide the joints. The four sides were mitred to try and get a sharp corner and all glued together with PVA. The roof was stuck on to the walls using double-sided tape and the ridge cut from strips of gaffer tape.
AS it took so long to paint the stonework on the depot, I thought I'd try a one coat and wash treatment. Dulux grey u/coat, dried and then washed with a thin coat of black u/coat and dabbed off.
Moss was added by creating splodges of green dashed with dry sand (left over from paving the drive). Doors were roughly painted and then, when dry, shoved back into the hole from whence they came, Ridge tiles painted with a dab of reddish brown.
Now I need to get the depot finished off. I was going to further detail the inside but, unless I illuminate the inside, nobody will ever know!
