I think that Beaver may be aluding to somewhat similar problems in Post #11, though he may of course be using other than LGB Standard Couplings.
This is only from my experience on my line:
On my layout (with the incline) I tend to mostly have certain trains using the same coupling through out the rolling stock of that train (except for when I temporarily 'mix' cars around).
I do use some LGB hook and loop (double hooked of course) in one train, but due to their not confidently handling the forces and pressure on the downward slope on a longish train. I will gradually swap them out to be replaced with knuckles.
I mostly use either Bachmann or Aristocraft or Accucraft (on 1:20.3 scale) knuckles.
Out of all the knuckles around, the Aristocraft jobbies have proved to be the strongest and able to stop the knuckles from vertical movement (so that they can slide out of each other and disconnect). They are a little big in scale though.
Bachmann and Accucraft knuckles are a close second.
Bachmann ones look a little better than the Aristo ones, they perform well and come in different shank length, and height configurations (for 1:20.3 stock).
Accucraft ones look the best on 1:20.3 stock and perform well.
Kadee knuckles look really great and are nearer to scale size. They are pretty good performers on the climb but can have real problems with a long train rolling stock forces on the couplings whilst rolling down the decline.
Lastly are the USA trains and LGB Knuckles.
The USAT ones are not very strong and can disconnect on the climb leading to a few minor disasters.
The LGB knuckles do not look great but they are strong and perform pretty well except for coping with the stresses exerted on them on a downward train
