The main reasons for using the 3mm plasticard Steve, are;Steve said:Making it out of plasticard may make it easy for you if you dont have the tools to make it from wood Giz
korm kormsen said:Gizzy, i urge you to reconsider!
there are better light weight options than plasticard.
look here: ????http://kormsen.ko.funpic.de/forum/viewtopic.php?t=426
Tony said:...doing straight brickwork is very differcult.
or you just use one of these little transformers, that plug into 230V and give you 110V....you need to make up a light dimmer switch on a extension lead so you can adjust the voltage to your soldering iron so its not to hot.
korm kormsen said:Tony said:...doing straight brickwork is very differcult.
not, if you use a metalic curtain rail as ruler.
