I am not. I got my track which was pricy. My engine and 3 box cars. I am looking for a 4th the at a good price. That is all I can pull with one motor. The other motor is weak and uninstalled. One day I might try and bring the motor from the rear of the engine to the front. That way I might be able to remove the front concrete weight I had to install. Then maybe add a 5th the boxcar. Now I am pushing it at wanting to have 4. Will I slowly expand ..yes but not like I did with ho. But all good I have sold most of my ho at a fare price.Ha Ha Ha ...
Yes very nice. Is the stone picture with the 2 bridges your layout too? Looks like you are on a quiet laneway. No show times sign yet. How many feet of track do you have? Looks awesomeQuick revamp and I'm only 2 feet short at the oveepass... this works for me!
Jon makes a fair point. However, I suspect most track power "problems" are related to poor initial installations that lack the due diligence to assure good conductivity across rail joints and adequate power feeds. I do regularly run LGB 50050 equipped track cleaning wagons which help keep my rails clean.The issue with track is all about cleanliness.
No the one with the 2 bridges is not mine. Haven't calculated total feet yet.Yes very nice. Is the stone picture with the 2 bridges your layout too? Looks like you are on a quiet laneway. No show times sign yet. How many feet of track do you have? Looks awesome
I will be experimenting with USA Track joiners, some piko rail clamps and I plan around 20 power feeds on this rather small track plan and see what works best for me. I still plan on going battery in the long run though.Jon makes a fair point. However, I suspect most track power "problems" are related to poor initial installations that lack the due diligence to assure good conductivity across rail joints and adequate power feeds. I do regularly run LGB 50050 equipped track cleaning wagons which help keep my rails clean.
No, life got in the way. I do have all the track I need now. Will get back to the layout soon. Looking forward to seeing your snowplow.How is your new set up Brian? I bet you got your train running on your new lay out by now. I am a week or two away from displaying my cp snow plow. Will make a utube video in Jan or Feb when we get some snow. The decals I wanted are out of stock. So I ordered stickers instead.
I have been aquiring some over time. Before too much longer I'll have enough to clamp the entire layout.Can you afford rail clamps? Those joiners will not be worth the maintenance effort, i.e. the extra cost of the clamps will more than pay for itself in reduced maintenance and above all, more time running trains, not fixing crappy rail joiners.
Even though I run "dead rail" I use clamps on nearly all my track, or Aristo-craft screwed fishplates, just need to get around to finishing off the rest of the trackCan you afford rail clamps? Those joiners will not be worth the maintenance effort, i.e. the extra cost of the clamps will more than pay for itself in reduced maintenance and above all, more time running trains, not fixing crappy rail joiners.
Clamps or screwed Aristo connections well worth while for dead rail as they help keep the track in place. Not unknown for rails to separate with only a fishplate due to additional pressure to the outside rail on curves.Even though I run "dead rail" I use clamps on nearly all my track, or Aristo-craft screwed fishplates, just need to get around to finishing off the rest of the track
That is one of the reasons why I use concrete. Prevents the tracks from moving around. But it is hard on the rolling stock when there is a derail...I really should switch to a higher smoother grade but I don't get the nasty details like I used to. If I was ever to sell the track I think I could get the concrete off. I just use o( plates.Clamps or screwed Aristo connections well worth while for dead rail as they help keep the track in place. Not unknown for rails to separate with only a fishplate due to additional pressure to the outside rail on curves.
Looking good and no, no update on layout yet. Still gathering Piko track clamps... almost have enough. Weather has been too hot to tear up yard. Was going to start today but new neighbors moving in across street has my front yard blocked up pretty good. I did aquire some more rolling stock, 2 more flat cars (6 total now) 1 tank car and one box car. Watching for crazy good deals on auction sites, been pretty lucky so far. Hopefully progress soon here. Next weekend they are calling for 32F here...in Florida!!! We'll see what happens.Want to make sure you got to see it. Still needs a lot of fine tuning. Head lights work. Yaaa ..anything new with your layout Brian? I have a snow plow thread for this.
