No such thing, just a purchase that you haven't found a use for. YetSee you have made your first purchasing bobo
Bobo - Yogi bear's associate.Bobo: An affluent and successful person who has a preference for countercultural ideas.
Booboo: A foolish mistake.
Bo-Bo: The arrangement of two, two-axled, bogies which is a common wheel arrangement for modern electric and diesel locomotives.
I'm all confused now... It could be any of the above.
OK, so Simon likes the tank. Maybe it was an impulse acquisition because it went bling! Nice blue it is.Perhaps it will later come into fruition with the 'master plan'.
Which Piko starter set did you purchase Simon?![]()
Transcendental trains!and diesel locomotives.
Yes, that too! Does LGB now make a Yogi set?![]()
Not that I know of, but like Yoga, watching trains is nice and relaxing.Bobo: An affluent and successful person who has a preference for countercultural ideas.
OK the OP likes the tank. Maybe it was an impulse acquisition because it went bling that will later come into fruition.
I left 2 of the o’s out so as not to indicate a foolish mistake, just a beginners whim for buying stuff we like that may not fit the master plan if ever one emerges. Certainly his 2 big bogie vehicles he has shown us do not fit in too well with the current inglenook, nice as they are.Bobo: An affluent and successful person who has a preference for countercultural ideas.
Indeed so, but I don't think he has got to that point yet.But he can run them on the mainline (in the garden) with the inglenook as a set-piece works alongside..
Lots of photo opportunities.
Just a case of wearing down the 'Domestic Authorities'..Indeed so, but I don't think he has got to that point yet.
However for safety the unit should give the voltage, if Euro (just less than our 240) then all will be fine. BUT if it says 110v then that fix a big NO NO and a new unit would be required.Sounds to me like you have a German domestic plug - For Germany there are two associated plug types, types C and F. Plug type C is the plug which has two round pins and plug type F is the plug which has two round pins with two earth clips on the side. Germany operates on a 230V supply voltage and 50Hz.
Snip it off and replace it with a British plug with a 5 AMP fuse.
However I think you should be correct Tac.
UK are also 230v, we moved away from 240v, and the EU moved from 220v to 230v in 2003.However for safety the unit should give the voltage, if Euro (just less than our 240) then all will be fine. BUT if it says 110v then that fix a big NO NO and a new unit would be required.
It's your railway, Simon, so you run it as you want to and with what rolling stock and locos.Many thanks for all your help everyone. It's been one incredible dayI went to Wickes, but the adapter plug I need was out of stock and so I went along to the local B&Q, where there were zillions of them and so, all I've done this afternoon (Saturday) is running in the loco. It runs, spot on. It's good value for the money.
I bought a Piko Eva tank wagon from Tim at Arcadia - his shop is fantasticI've ended up with a handful of wagons and a shunting loco that would never go together in real life and this was only meant to be a tiny, LGB field railway......
More like an addiction.It's your railway, Simon, so you run it as you want to and with what rolling stock and locos.
Over lunch last Wednesday, I was talking to someone of 84 who described model railways as a "disease" (his main interest is 45mm, but he also has O and N, and too much of each!). I know exactly what he means and you seem to have caught it, too, so just enjoy having it.
Either way, there's no cure!More like an addiction.
