Help with LGB 10345 Automatic Shuttle Missing Track Pieces
kidzntoyz
I purchased the LGB 10345 Auto Shuttle and it was supposed to be new and complete but instead is missing the isolated track sections and diodes. Since I am new and have a lot to learn regarding electricity, could I instead use the isolated track 10153 (1015U) to complete the setup for prototypical braking according to the instructions for the shuttle unit? I thought that might avoid soldering but I do know how to solder if needed. Or should I just cut the rail of a piece of short track?
Here are the instructions: 2. Connect terminals “sw” (black) and “ws” (white) on the circuit board to the insulated track section. Loosen the screws on the insulated track sections and trap the wire between the screw and the rail. 3. Use the blue/red track power cable to connect the connectors ”bl“ (blue) and ”rt“ (red) of the terminals, respectively, to the tracks. 4. Use the blue/red connecting cable to connect the connectors ”bl“ (blue) and ”rt“ (red) on terminal “Power” of the circuit board to the DC output of an LGB throttle or power pack. 5. Plug the power supply cord into a house current outlet.
Thank you for any advice!
I have the Isolating track but no diodes. Any idea what the diode names or specifications?
