Greg Elmassian
Guest
Here we go, grease is not conductive, but the electricity will get through... a light grease will still allow conductivity.But surely grease in NOT conductive, so will reduce or even eliminate the contact usability.
Lps and Deoxit are not conductive either. But while it goes contrary to "logic", enough metal to metal occurs that grease coated contacts will pick up.
Also LGB conductive grease is NOT conductive. And you don't want to use real conductive grease, it tends to get everywhere and you get shorts.
By the way DeOxit is great stuff, to keep oxide buildup down, it leaves a thin anti-oxidation coating down.
If you don't know this stuff, happy to educate, but we should start a new thread, since "common wisdom" will be opposite to what I am saying. (but electrical engineers and physicists can explain).
The key is that the contact patch is very small, and even with grease on it, some metal will be in contact.
