how to turn off track powered lights
BEEF BOSS
24 Sep 2022
11
Bend OR
Hello, just so you know, I have not bought a lighting system yet so im looking on G Scale Centeral for answers for some of my questions, with that out of the way, I was wondering if there was a way to turn off the lights in a coach that are powered by the rails, because in the daytime I dont want any lights on in any of my coaches, caboose, or any other rolling stock.
Thanks!
Wistow vale rlwy
20 Feb 2010
263
38
WISTOW NORTH YORKSHIRE
Hello Beef - I would just fit a small micro-toggle switch (or similar) in an out of the way place on each carriage and use it to switch the lights on/off as required.
Best regards, Graham.
1,715
As Graham says, fir a small switch
JimmyB
23 Feb 2018
7,001
929
70
Weston-super-Mare
www.tumble-down-falls.co.uk
Thanks!
Why turn them off, they would probably not be visible in daylight, and if they were, then maybe they should be on.
5,009
76
idlemarvel
Neither idle nor a marvel
13 Jul 2015
3,136
801
Ascot
Mars
Agree with all the above, but just to add a few options.
LGB locos often have an external power socket to which you can plug their coach lighting kits. The advantage of this approach is you don't need metal wheels and power pickups on your coaches, downside is you have wires along the train. By default these loco power sockets are always on but you could put a toggle switch or reed switch in the loco as above.
Or if you have DCC you could reroute the power to the external power socket from a decoder function output. You could then switch the coach lighting on and off with a DCC throttle function button, or the loco lights button.
If you have DCC then an expensive option is to put a simple decoder into each coach then you can control the light to each coach individually.
Not necessarily recommending these options, just adding them for completeness. The simplest option is in post #2
Rhinochugger
Retired Oik
4,254
North West Norfolk
Thanks!
I'm tempted to say that I wouldn't worry - in daytime you're probably unlikely to see that they're on :think::think:
BEEF BOSS
24 Sep 2022
11
Bend OR
Alright, thanks!
ntpntpntp
275
UK
United-Kingdom
I'd say yes fit a miniature slide switch or toggle switch somewhere underneath and unobtrusive, if the coach doesn't already have such a switch. I would rather not be drawing and wasting power for lights when there's no reason for them to be on.
The Shed
Citizen of the Republic of the North East.
8 Mar 2020
1,073
239
Darlington, County Durham.
England
Content updated.
