I think if you want "reasonably squirrel proof" concrete or resin or kiln fired clay is the way to go. Foamex (is it called Sintra in the USA? ) is reasonably weather proof and light (easy to put away). you can paint it with weather resistant paint of your choice and add marine varnish if you want. You may want to construct it so its easy to add weight with rocks, bricks etc. You may want to fill or close it off so critters can't nest in it. The main advantage of Foamex is its versatility. You can score bricks and planks into it, cut it with a craft knife, paint it, or get your designs commercially printed onto it, or print yourself onto paper, card or adhesive vinyl film. This means you have complete creative control over what you produce.Is anything squirrel proof!!
I display indoors so it's not an issue for me but if you are using it outside you would need to weight it down. On one of my other recent posts I have outlined most of the issues regarding using it outdoors, ink fading, critters etc.Computer says it is a light weight PVC. Do you weight it down to prevent it from blowing it away?
Foamex buildings might suit you then. Winter in the basement then out into the garden for summer. Just make them to an outdoor standard with weighting, critter proofing and some varnish finish for extra protection from rain and strong sunlight. Maybe place them in the shade if possible.Yes big difference inside or outside on the garden. I want to set up 83 plus feet in my basement from some time in November to April. Rest of time in my evergreens/flowering plants garden.
Yes if I do indeed go that route. Many years ago I had a buddy that I have known since 4 come over for a visit with his hot gf. Well I was showing him around the house and came to a spare bedroom. Before I opened the door I said being a hospital tough guy I really need a training room. I opened the door and they saw my first ho train lay out spread across the floor. He then said what are those boxed scattered all over. I told him they were buildings. In a deep thought he said...ohhhh....They were small boxes spray painted grey with lines depicting the many floors. So just goes to show you that if you use your imagination you can use just about anything for scenery on a model railway. As per wildlife that will be an issue. I have lots of squirrels... Plus a puppy that rather than run.. likes to hop like a rabbit.... higher than my waste.Foamex buildings might suit you then. Winter in the basement then out into the garden for summer. Just make them to an outdoor standard with weighting, critter proofing and some varnish finish for extra protection from rain and strong sunlight. Maybe place them in the shade if possible.
