But now we'll know where to look!Makes a great place to keep valuable things securely in a house, better than a safe.
Hmm. Can't get video to play, alas. But I like your taste in boardgames.but talking of portals to other worlds, this is how we access the garage...
Yeah but Jon is a railway buff - bigtime!But now we'll know where to look!![]()
That is correct! I'm going to try the prototypical approach to start out out with. It seems the answer to, "how do I lay my track", like many questions in our hobby has a range of opinions. You can just about see in the last picture I've already tested some gravel. I'm using crushed granite as it is locale, in keeping with the colouring of the rocks on the layout and sharp to catch other pieces. The first trial seems to have gone well. I will, however, wait a while before doing this because the soil isn't ready yetAll looking very nice, though it does raise one question, I assume that the track will not be left on bare earth, slabs, blocks or bricks underneath, or a lined trench with ballast infill will support the track.![]()
I appreciate the advice and will likely apply it! I've only been mixing compost in so far. The problem is the clay just loves to clump. You can see in some of the pictures even with extensive forking, it's still there. It wasn't too bad when I was working it after 3-4 dry days, but even a light rain makes it a pain to work with. As I said to Jimmy, I'm going to defer ballasting for now with the intention of reworking the soil when it is drier to get some of those clumps out!Having had a garden that was predominantly clay with flints (Hemel Hempstead) I sympathise with you issues. What I did was to sift all the earth breaking it up as much as I could, stubborn lumps of clay were bagged for dumping. Good stuff was mixed with soil conditioner, fine rockery gravel and sharpe sand. Not sure if the sharpe sand will be easily available where you are as you certainly do not want to add salty sea sand for growing plants. The stuff was mixed up in the cement mixed to give a really good planting medium that rewarded the effort with a good rockery growing area. no gravel woukd be used where normal plants are required.
There are two. They are both accessible but the longer one is less easy but is straight most of the way (only curving at the entrance). For the longer tunnel, under the soil, the a slab and the cover are removable. The shorter one is accessible from both sides. My plan is to add a guard rail that follows it round to derisk it.Looking good Curtis. How accessible is the tunnel? That's where de-railings always seem to happen, or animals like to nest, so easy access is a must!
Wow! That's gone up in price since I bought mine (10 years ago)!I told you the spelling was wrong..
Hob E lube 7 Pack Workbench Assortment
Precision lubricants for craftsmen! This super-saver value includes all seven lubricants plus complete instructions that spell out precise applications and the exact lubricant to use. Be prepared. Know where and when to use which lube: nonconductive, nwww.hobbies.co.uk
Regarding the membrane, how would you do it? just following the line of the track +5cm each side?
Thanks for sharing,My ground level track is on a membrane in a trench, and I learnt a few lessons along the way, the main one was not to skimp on the membrane, so line the bottom and sides, and them at least 5 cm each side, also consider how you will retain the ballast if your track is level or rises above the the ground.:
Tumble Down Falls
After a year I have come up with a name for my railway, as you will see from the title Tumble Down Falls. I plan to put some of my earlier photos of the railway here, and add as the railway progresses. Apologies to those that have seen the photos before, but this should keep thing together.www.gscalecentral.net
