One fast question from newbie. I have found a local second hand seller selling a lot of tracks, and he sells the "Electric Double Slip Switch, 22.5°" from LGB in a good condition and very good price. My question is, it can be operated in manual mode?. At first, i prefer to operate all switches in manual.
Thanks!
The switch have two black point motors, its the new version. So great info, thanks!
Great! Thanks Zerogee! Also, clamps are always necesary? Any recommendation there?
About power system, the piko starter with the BR 80 seems to be very interesting, but it seems to me the controller and power system from LGB are better? If i go to DCC are decoders compatible from PIKO locos to LGB DCC control?
Thanks!
Hi,So over on the other side of the pond you only have Piko and LGB to choose from ?
Have you thought of flex track and installing sweeping curves with all that space ?
I'm spoiled I guess , working so close to USA trains .. I have 20' diameter curves on one of my loops , the other 8' & 10' s . and my flex track came from Train-li : https://www.trainli.com/
Hi,
I've come across some USA Trains track in the UK. Do you happen to know if it is compatible with LGB?
Thanks!
That's vey helpfull. Thank you.Yes ...
I have both or all 4 ... USA , LGB , Aristo , Train-li (Pro-line ) all code 332 all compatible .
ProTrack G-scale Flextrack rail 6' (1.8m) Brass (20 pcs)
USA track was made by the same company that made the Aristo track
Tracks arrived. Aristocraft and LGB and 100% compatible. I will try a test layout this weekend and will share some photo.
