Yes, I have been told I need to re wire the historic set buffet car for the yellow bernina ,I replaced all the table lamps with led. .. I know it will only light up in one direction on anolog , but on dcc ,it works fine,
For DCC only you could put half the leds the opposite way round to the other half in each coach This could halve the peak current drawn.Yes, I have been told I need to re wire the historic set buffet car for the yellow bernina ,I replaced all the table lamps with led. .. I know it will only light up in one direction on anolog , but on dcc ,it works fine,
Yeah, or build your own wheatstone bridge.Or you put a 50p bridge rectifier in as well, and are sorted!
As a teenager I had a Honda 150cc bike which unusually for those days had an alternator. The plate rectifier died, and the Honda part was blooming expensive, so a friend of my parents who was an electronics whizz with Decca built a wheatsone bridge replacement - Honda ran finecost me £2 for diodes.
Just another opportunity to share my lack of knowledge<pedant mode ON>
A wheatstone bridge, is where you use three known-value resistors to find the value of a fourth resistor of unknown value..
A bridge rectifier, is either an encapsulated device, of made-up of four diodes.
</pedant mode OFF>
Thanks paul..Very neat buffer lamps Mike.![]()
