FrenchChuffed
Amazing modeling as always that is Fantastic, can you remeber where you got the Ford Anglia from? it was my second car
It is the Titfield Thunderbolt - not Titchfield
Your sign putter-upper seems to be a couple of letters short of a title - or is that intentional?
Correct:It is the Titfield Thunderbolt - not Titchfield![]()
"A good day in da shed...well it was moist out. windows fitted .,lamps fitted over exits and posters,posters fitted,,as is the name of the film showing now..
Tichfeild thunderbolt
3 parts of building joined up as 1 now..View attachment 311458View attachment 311459View attachment 311460View attachment 311461View attachment 311462
As you can see I was misled by Mike!It is the Titfield Thunderbolt - not Titchfield![]()
Yeah, I blame Mike"
I can not lie, being dislectic, I copied the movie posters spelling...VERY,VERY CAREFULLY, as I only just had enough ts on the set of letters..
Yeah, one of the 00 manufacturers is bringing out a model of the 'entire' train as part of the 70 years celebrations.![]()
The Titfield Thunderbolt - Wikipedia
en.wikipedia.org
Just needs a queue of people outsideTrip to see my mate Paul.. fitting a xls in the wizzy cranks...now sorted..
Pavement got a coat of gray...
Had a light bulb moment with the cheap Chinese led lamps...my problem being they are O gauge..and thin brass tube..no base .no way of fixing them in to the pavement.
But by removing the plunger...and dropping a penny washer on the syringe..open the needel hole up a bit..well..you get the idea
Time will tell..View attachment 311972View attachment 311973View attachment 311974View attachment 311975View attachment 311976
Cunning!Had a light bulb moment with the cheap Chinese led lamps...my problem being they are O gauge..and thin brass tube..no base .no way of fixing them in to the pavement.
I see you have a number of French cars on the streets. Who are/were they made by (the model not the car itself!)?If it works it will be..
Sun was out...so I removed the low retaining wall, and tried the pavement, for fit/size...then I could position the last lamppost...and wire them up..central hub
Then fit the Empire Cinema..
View attachment 311990View attachment 311991View attachment 311992View attachment 311993View attachment 311994View attachment 311995View attachment 311996View attachment 311997
Solido 1/18, or model car group, 1/18..I see you have a number of French cars on the streets. Who are/were they made by (the model not the car itself!)?
