Lazy Grange Bay 3...a new start
Thanks mike think i may purchase one or to of these, the bus is fantastic looks good cant wate to see more realy inspireing to see it grow
Jim
I keep looking, and looking:thumbup:
Village of the year!:thumbup::thumbup::thumbup::thumbup:
That pick-up looks so damn good too:thumbup:
cheers guys , mick, the pick up was a gift from a mate when i weathered a lgb loco for him, its slighty over sized ,1/18th scale, but looks ok if kept away from the other 1/24 scale stuff...hot day out, trimed me bushes..sandy arived just in time for a brew and a chat..sneak inspection off the cobbles..the lgb gas lamp company instaled 5 more today, 2 at the bus stop, and 3 around the market site. had a idea for the bolards to go around the market..asda biro pens, pondering
:bigsmile:testing the new lamps..
started laying out the track for the coal merchents yard today..reasionbly happy.. fitted point mortors to all the yards points, just gotta program the switch drive..and the trainline point motor as well the yard throught point, along with the wheel chock, will be point no,5 :q26: did some other bits tootrains,off course ran, and now, i can change the point into the shead.. so as off today, i can drive stock in,or out.. :q25:
:q25: thought id post this, it might help.. after repaireing several trackcleaning loocs over the years, i think i can honestly say its a cracking bit off kit, IF YOU LOOK AFTER IT..no names ,no pack drill..ecti recomend that you REGULARLY check behind the cleaning wheels, i do mine, every 3 run.. i run mine for a hour at a time. so every 3 hours worth off off cleaning. it dosnt take long ,it WILL prolong the life off the loco, and SAVE YOU MONEY>>turn the loco upside down, remove the surporting bar, 2 philips screwspull the cleaning motor ,back towards the cab.. till the 2 retaining lugs, clear the boddy ..lift out the cleaning mottor block, remove the flat head screw, and remove the cleaning wheel ..just like you would, to change a cleaning wheel.. after beeing used, the nylon black plastic wheels, de laminate..they become, nylon string.. this, raps around the axles.. traped between the wheel, and the motor block, it builds up, into a larger mass. it gets hot, as its causeing friction.. melts, and is pulled into the ball bearing axle asembly, by capillary action.. were it sets.. back into nyloin.. this in turn leeds to the claeaning motor, reqiiureing more power to operate.. this leads to a catastrpoic failure off the main electrical system.. a blown main bord, a burnt out motor, and a seased up ball bearing axles asembly.£££££££...or you can just clean out the nyloin string and save your self, some greif, and a lot off money.. its up to you :q26:
hi james, yes..im hopefull that the hammer fairy will come up trumps again..
last job is the ballasting.. :thumbup:
just back from a dAY out at diggle vally, we went on a raiding party to P+S HObbies in york, manged to buy a small waggon for the pricely sume off £75.. ..
so home, tea, testing
Oh Yes:bigsmile:
Parts now being delivered to the FSF via rail:thumbup::thumbup::thumbup:
All you need now is a spur into the kitchen :rolf::rolf::rolf::rolf:
:cool:forced my self to eat a tub off icecream.. needed the container, for use in the protection off a lgb switch drive..which i fitted today.. wired up the points in the coal yard, and wired in the trainline point motor, it will motorise the wheel chock, on to the rail, when the leading point into the yard, is set against it.. and off when the point is set for..also got the cocktail staires for me bolards.. nice day to run trains..
check out the vedio
http://youtu.be/zgyI2w9buwM ...cket.com/albums/s446/kmet2/P1100834.jpg[/IMG]
Ooh ooh ooh ... where did the stirrers come from ? I've trashed all my tram stops, so I need to make some more.
Nice job with the wheel chock.
evil bay daveid, £2.00 for 30 i think, and ta:bigsmile:
market daypens for bolards, cocktail stirs for the ball tops..imagination by mike:bigsmile:
I am not going to look at this thread any more....I just get depressed that you layout progress moves much faster than mine i will never catch you up:brokeheart::brokeheart::brokeheart::brokeheart:
Looking excelent though Mr D:thumbup::thumbup::thumbup:
bring cake, and jack Ds all progress will stop:bigsmile::rolf::rolf::rolf::rolf::rolf::rolf:
cheers matey
Pens look great for bollards, been thinking of a similar solution using earplugs, just need a use for them now :bigsmile:
haveing the imagination to use stuff is great matthew,..no.1 dishwashers-emmas here ,so the build has slowed.. today i was fixing down bushes..bought a plastic topraie ball from a garden center.. split it, and pulled off the plastic leaves, they make great bushes..fixed down with a screw ..
today i felt .like makeing the limet of shunt ,markers , i have used my favoiurt cocktail staires, useing the ball end.. a coat off white paint, and a red splash.. drill a simialr sizes hole in the basebord.. and job done ,got abit more off the plastic folage fixed down.. had the wanagro red desile running, but it kept stalling on a point.. multi metter out.. point was ok..checked again, still stalling.. so turned my atention to the little shunter, fliped it over, one skate wasnt showing a conection with the multimeter..and it was stuck, no movement.. so after striping down the motorblock, wheels outy, bullets out, it seems that the moulding that holds the skate, had ,deformed.. i finally got the skate out, the spring, seemed fused to the plastic.. drilled out the moulding, new skate, new spring, rebuild.. test with mulitmeter.. now works fine
