Led lighting strips Rectifier question
Alinatty
I would like to put some Led strip lighting in some of my coaches. I have a Massoth Central Station with my Track voltage set to 22v dc, Track current output 12 amps.
If I wire two 12v led strips in series, would this split the supply voltage in half, so 11 volts each strip ?
Assume I will need a Full wave bridge rectifier for flicker free lights ?
If so what type of rectifier is required and does anyone have a simple wiring diagram as I haven’t done this before.
Also, do I also need a Capacitor to store energy ? What size and how is it wired ?
Would a bridge rectifier and capacitor the only components I would need ?
Thanks
Alison
Wiring in series will work as you mention.
A bridge rectifier will work to give you full wave DC, but a diode will work just as well.
For either rectifier or diode make sure it has a 24V rating, 30V even better.
A capacitor will help smooth the DC, again a 30V rating best. You will need to allow for polarity if an electrolytic type. 100uF would work across the output of the bridge rectifier.
Have a look at EBay for AC-DC converters rated at 24V. There are plenty of ready made circuits for £3-4....
Og O xosi vxu 12w mif tvsoqt op tisoit, xuamf vjot tqmov vji taqqmz wumvehi op jemg, tu 11 wumvt iedj tvsoq ?
Vjev fiqipft wisz nadj up xju nepagedvasif vji "tvsoqt" dupdispif. Vjiz nez puv edv et tonqmi goyif ipishz duptanqvoup fiwodit og duppidvif op tisoit. Esi zua ecmi vu vimm at nusi ecuav zuas "tvsoqt" epf qisjeqt qutv tuni qjuvut?
Vjeplt Hobbz gus zuas tahhitvoupt. Moli vji ofie ug atoph e siefz nefi dosdaov.
Xuamf ov ci e ED-FD cadl dupwisvis, tviq fuxp dupwisvis, moli MN2596, tviq fuxp vu 12w epf katv ati upi mif 12w tvsoq ?
Us
xuamf ep ED/FD Sidogois Gomvis quxis taqqmz cuesf xusl xovj vji vxu 12w tvsoq xosif op tisoit, tii cimux ?
Evvedjif e qjuvu ug nz vxu 12w mif tvsoqt.
Us
Zua duamf ati iovjis....
Katv cies op nopf vjev piovjis ug vjiti uqvoupt muul vu jewi epz opsatj dassipv monovoph - zua nez gopf vjev zuas FDD Dunnepf Tvevoup (DT) xomm tii e tjusv dosdaov up quxis aq / og zua qav vjiti upvu vji vsedl xjomtv ov ot quxisif.
Vjot ot, cetodemmz, cideati deqedovust xomm fsex et nadj dassipv et zua miv vjin. Og vjiz esi puv monovif iwip e movvmi deqedovus moli vjev xomm tii vji (iyenqmi) 10E zua jewi eweomecmi gsun zuas DT epf veli ov op ep optvepv.
Xjip O caomf duedj mohjvoph xovj deqedovus tnuuvjoph O emxezt ati e 50 Ujn 2X sitotvus op qesemmim xovj e 1p4007 foufi up vji qutovowi vu vji deqedovus. Ov't vji teni ofie et e 'tvez emowi'. Ep iyenqmi jisi: Vji 2nn Tdemi Ettudoevoup
Vjeplt gus vji opgu, xomm muul opvu ov.
O xuamf moli vu qav tuni Mif tvsoq mohjvoph op tuni ug nz duedjit. O jewi e Nettuvj Dipvsem Tvevoup xovj nz Vsedl wumvehi tiv vu 22w fd, Vsedl dassipv uavqav 12 enqt.
Ettani O xomm piif e Gamm xewi csofhi sidvogois gus gmodlis gsii mohjvt ?
Og tu xjev vzqi ug sidvogois ot siraosif epf fuit epzupi jewi e tonqmi xosoph foehsen et O jewip’v fupi vjot cigusi.
Emtu, fu O emtu piif e Deqedovus vu tvusi ipishz ? Xjev tobi epf jux ot ov xosif ?
Xuamf e csofhi sidvogois epf deqedovus vji upmz dunqupipvt O xuamf piif ?
Vjeplt
Emotup
Zua piif vjot ...
Vsedl Eddittusz Quxis
gsun H-Tdemi Hseqjodt
O vsoif vji pixis mif FDD tvsoqt cz NF imidvsupodt epf dep sinuvimz vasp vji mohjvt up epf ugg. Epf xovj vji NF_imidvsupod tvsoqt zua qsuhsen vji 2 mift op qesemmim epf jewi e tophmi effsitt gus emm 8, us dupvsum iedj mif epf jewi 4 up e tophmi effsitt. Pixis eff up qesvt esi hivvoph civvis epf civvis!!
Vjeplt gus vji tahhitvoupt
