AAMOI, how long have you been around? I've been into model RRs and modelling in general since Airfix actually began to make plastic models that didn't warp in sunlight, and I'll admit that until yesterday I'd never heard of you.
Tac, I did some testing for Archer of the decal rivets, and they just weren't tall enough for F scale. Custom Model Decals might be able to get more resolution.
Keith, here's another couple of options that we explored on LSC a few months ago.
Vinyl cutters, which cut white sticky vinyl to shape:
Large Scale Central - Advanced Forum Detail Topic - Fun with the vinyl cutter
White laser cartridges:
Large Scale Central - Advanced Forum Detail Topic - White Toner for Laser Printers
Yep, you then have to 'fix it' with varnish, which doesn't totally fix it when you start to soak / apply the transfer. Then it degrades / runs when stored in a less than completely dry atmoshphere.You can buy inkjet Water Slide decal paper and print your own decals, I have looked at it but not bought any yet and tried it, don't know if anybody on here has tried the stuff, it's around £15 for 20 A4 sheets so not expensive if it works ?
No it is not, tacF scale is actually called Fn3 - F for Fine, n for narrow, and 3 for the replication of the mostly-Colorado 3-foot gauge lines that proliferate in that state.
tac
Ottawa Valley Garden Railway Society [ovgrs.org]
Some waterslide are pretty good at adhering to the surface and reflecting the surface features - Fox transfers (I have used quite a lot of their standard lettering) are very good for that and don't require a gloss surface - it must be all to do with the carrier film I guess.I suppose in the larger scales, between 1:29 and 7/8th inch, in this part of the railway hobby the issue will be understanding and deploying the typefaces/fonts used and the conventions around likes of lining and drop shadows with text and numerals associated with the older subject matter that predominate here. This is where the established players like Stan Cedarleaf and others score. As I have come to appreciate recently getting some decals made up for a D&RGW Fn3 subject.
It surprises me that the availability of "print on demand" decals in the dry print medium are not more prevalent here, or even a seemingly waning technology. Vinyls seem to be taking their place and I have used Del Tapporro's good services for my lumber line's roster decoration. Both technologies are ideal for white and metallics, the bugbear of CMYK and RGB low volume printers, that is the basis for a lot of RR liveries and decoration. But I prefer the qualities of dry print for its ability to better conform to textured surfaces.
My issue with waterslides is that they must inevitably be applied to a gloss surface, to help hide their carrier film, requiring a prior and further overcoating to achieve the full final desired finish. These are opportunities to muck things up, for a variety of reasons, no matter how experienced you are. They also more often or not need some kind of setting solution to get them to conform to textured surfaces. Personally I have no problem using them as I spent many years applying them to 1:43 racing car models that are stuffed with compound curves, shut lines, rivet heads and undercuts for them to be conformed to, which is not such an issue with model railway subjects. But at least a racing car's paintwork and the decals invariably have a gloss finish. Max
I see the problem with the 3D business - Archer, of course, are famous for their products in support of N, H0, S scale and 0.
I have no doubt that you'll also get asked at some time for your products in 7/8th scale - a narrow gauge scale that is getting very popular with a number of live-steam and electric models produced as ready to run live-steam - Accucraft - and kits - IP Engineering and Model Earth, just to name three.
Irish narrow gauge, mostly three-foot, is also on the point of becoming popular, with Accucraft promising to produce live steamers in that scale, and South African prototypes as well. The Isle of Man is already well taken care of by Accucraft, since it also runs on three-foot 3 gauge.
You have joined into a huge on-going party here, and I wish you the very best of luck!!.
tac
Interesting - I've never got on very well with Decalfix - it can leave a white sediment that's impossible to remove. Mind you, I was trying to apply some pretty ropey white transfers on a black background. They were purpose made, and the seller was very briefly on either this forum or its predecessor, but he wasn't around long - can't think whyAnd the use of modern decal fixing solutions. Humbrol Decalfix is a one part solution that I recommend to my customers. It greatly reduces the ‘silvering’ of waterslide decals when they are applied to matte painted surfaces The Vallejo system is two part, one part used for application and the other the decal softener. I have good results with both systems with our decals. The days of using just water to release the decal from its backing are getting fewer.
I am trying to expand the range of features I can use for decals and custom rub down and decals with Ink and metallic components are on my list of future experiments.
Interesting - I've never got on very well with Decalfix - it can leave a white sediment that's impossible to remove. Mind you, I was trying to apply some pretty ropey white transfers on a black background. They were purpose made, and the seller was very briefly on either this forum or its predecessor, but he wasn't around long - can't think why![]()
Have used so called decals, pressfix and metfix with varying degrees of success. My latest set of decals from Germany whilst very good were as ever for me a bit of an issue to get right on plastic stock. My greatest success in the past with 00 and 0 gauges was Methfix, I found the ability to move around the numbers and lettering to get things straight and in line an enormous benefit, for me they worked a treat. However sadly not available any more, but I have sufficient for my current needs in the smaller scales. If only they (PC Models I think) were still on the go but nothing lasts forever I guess.I suppose in the larger scales, between 1:29 and 7/8th inch, in this part of the railway hobby the issue will be understanding and deploying the typefaces/fonts used and the conventions around likes of lining and drop shadows with text and numerals associated with the older subject matter that predominate here. This is where the established players like Stan Cedarleaf and others score. As I have come to appreciate recently getting some decals made up for a D&RGW Fn3 subject.
Just a warning, Humbrol Decalfix is not the same as it was. I have 30 year bottles of Humbrol Decalfix 1 & 2 and now the Humbrol Decalfix is a single bottle system.
see
You may want to provide a warning, if you haven't already, in any instructions given that the product you are recommending is not the old/original Decalfix. .... Max
