KeithT
NeilNeil Robinson said:If they are genuine LGB the yellow screw-in type are 18V.KeithT said:Initially, I wired the lights in so that both front and back were 'on' together but they seriously overheated. I assume that they are not intended to run at the full 18V and would have had their voltage reduced by the original board; the bulbs are the yellow screw-in type.
If they are running too hot and/or bright you could always wire two or three in series.
Good thinking I will try that and at the same time find a home for those 4 'extra' screws.
