David1226 Registered 24 Oct 2009 7,968 7,969 74 Abingdon, Oxfordshire Country Best answers 0 6 Sep 2023 #21 richand26mhz said: Fixed using a 2mm drill bit. As said above I drilled the hole with 2mm drill. Then cut the drill bit down to use as a piston. Thanks for the info. Click to expand... Glad to have been of use. Below is a gratuitous pic of the U-Class that I had to repair David 1 Show all
