I have one of these sets to fit a Massoth XLS sound decoder (more on that later!)..
First thoughts:
This is a cracking piece of kit!
Definitely in a different league to the E10 (budget, `Piko killer` model). The whole package screams quality and attention to detail. Very crisp mouldings and graphics. Nice detailing on roof and bodies.
There are a number of `gotchas` to be aware of though.. It would appear that you will probably have to run the rake of three vehicles. - NOTE: I have not tried this yet, but it has been reported that you are not able to run as even a two-car unit.
Electronics are in the centre car, so this is where you will find the switches. - NOT in the Engineers cab, as the paperwork states!! ???
The switches are on the LHS inner wall of the B centre car. You will need to use the (supplied) suction cup to open the pair of RHS doors to reach across to these switches.. My guess will be many will never need to touch them! They are at the front (catenary end) of this car, roughly where they `wheelchair, pram, bike` logo`s are printed. - no excuse for not finding them now.
The cars are a very good interference fit in the expanded polystyrene packaging.. I have found the best way to get them out is to bunch-up the plastic sheet at either end of the car and lift them out with this.
The cables to connect car-to-car are keyed, and certainly initially, very tight to remove once they are in. - They will ease with use, but if you ease out the `keyway` side of the socket with a fingernail, it helps.
There are switches for catenary/track power, and the obligatory 4-way power switch; 0-off, 1-lights, 2-motors and lights, 3-as position 2.
Normal rules of analogue ONLY for catenary power. The destination lights are a strip of five surface-mount LED`s per window, and a selection of destination overlays (plus other decals) are included.
I am going to need a lot more than my customary four-foot of track to set this one up, so it will be a day or so before I can give many more details and thoughts..
Massoth have provided an XLS decoder programmed with the correct sounds, and it will be interesting to see how this compared with the factory fitted examples. Massoth have also supplied wiring information for me as this unit uses two of the 10-way interface cables. - More on this once I get inside the beastie!
First thoughts:
