Rhinochugger
Retired Oik
Though why three big, black screws in the rear of the cab?
Difficult to find a rear view of the 1:1 loco to check whether they're scale screws
Sometimes the predictive text goes haywire. I know I typed in steam.do we actually have a section for that?
Nice review thanks Stockers
S'not the same loco - I mean apart form the colour, that's got outside frames
And a different cab side number too?S'not the same loco - I mean apart form the colour, that's got outside frames
.................. and no screws in the back of the cab
Gosh! That's ugly!
Look's like a lorry-cab? - On backwards!
the big wheel controls the gears
Still can't be right - it hasn't got any screws in the cab back plateVoila - here is the V10 C from the Prignitz on 750 mm track.
Note the outside frame with the counterweights. The 1000 mm variant like the HSB version has the inside frame.
View attachment 264451 View attachment 264452
Was there a CV that allows it to run on an old Serial MTS 1 or 2 setup with 14 speed steps?The air intake on the bonnet pulls out and exposes a screw head for volume control. I wonder how many bits will get lost!
It is a reasonably heavy loco and I guess it will pull more than the original, but maybe not up my new spiral. It walked it, easily, with 3 four wheelers though.
Now, the Mfx decoder. You need to be careful using anything but Marklin gear but it is easy enough without. With the Massoth kit I find it easiest to work with individual CVs rather than allowing the system software to change a range of CVs. Or just get your dealer to do it for you.
CV50 selects which operating systems are 'on'. The default is everything being on. Reduce this CV value by 8 and you switch off Mfx.
CV1 sets the address. From 1 to 127 I think. I used 68, the end of its running number. If you want to go higher you need to adjust CV17, 18 and 29.
This is where the standard non Marklin software can lead you astray if you let it try to do everything for you. I did it as an experiment and it changed CV18 to 0, it should have stayed at 128 - the default. Easy to correct if you checked it first! With the wrong value in CV128, your loco wont work!
If you want to play with some of the higher CVs (and you probably never would want to), you need to unlock them by adjusting specific CVs. - it is all in the instructions.
I wouldn't know for certain, but I would doubt it....Does anyone know if this will work with MTS 1 or 2 Serial control units?
I have a Parallel MTS 2 system which I use on my portable shunting layout, Hardyard Jon.I am unsure if it would work with pre P LgB. However as serial is just a different way of sending the packet would it work? After all serial locomotives did work on LGB P system. B Big Trak does not declare where he lives, I have a reasonably modern Marklin LGB loco that could be tried if you are anywhere near St.Neots. PM me if you are, include your phone number we may be able to arrange something.
