Okay thanks guy now another newbie question how do I change the light settings I can't find out how and I noticed one of my other locos they are to bright thanks
Okay how do I go about changing them sorry for all the questions
I used this tortuous route to change the chuffs on an LGB Sound Sachen Meyer for a mate, tricky but it worked. Should do for a Massoth Chip as well - note the should do! As a starter you could try changing CV 1 first, if that works OK you will be on your way. Make a note of what you changed it to, I like to use the Loco Numbers last 2 digits if possible and a Sticker on the bottom of the loco. Note you will only be able to use 01-22 with an LGB Setup. Though the Chip will allow 001-999 I think.Dose this make any sense I have printed off the instuctions for a lgb 55021 decoder will this work for my massoth View attachment 235579
I already have the decoder and installed it I've changed the loco address, I know how to do that it' just the lights I need to sortI am sure that, if you buy the decoder from a reputable dealer, they will change CV50 before sending it to you - and change the address if you want it. Try Mark at Garden Rail Outlet.
http://gardenrailoutlet.co.uk/
The only thing I need to do is the one for the lights so I don't blow all the bulbs
