Madman said:I picked up the book, "The World of LGB". From that time on, the EPL System has made good sense to me.
korm kormsen said:Madman said:I picked up the book, "The World of LGB". From that time on, the EPL System has made good sense to me.
for those, who are interested, i have a copy of that book online.
it is a .pdf, so easy to download.
on my site (link in the signature) scroll down, it is the last link on the left side, called "copy of lgb manual".
Half wave rectified, is that the safe way of doing it?peterexmouth said:Just to make things a bit clearer, the 2 contact LGB point motor operates on DC. If you have a 12 to 18 volt dc supply or battery and connect it to the point motor it will move to one position (if it is not already there). If you reverse the supply it will go to the other position. You only need a momentary contact to make this happen. If you leave the supply connected to the point motor, then it will get hot and not like that very much, but up to about 20 seconds won't hurt. The motor has a resistance of about 22 ohms, so if you operate it with 15 volts you are heating it with 10 watts. The dc supply can be obtained from half wave or fullwave rectified AC , or a battery, and the current drawn will be about 0.7 amps.
Peter
steves said:Half wave rectified, is that the safe way of doing it?
Neil Robinson said:You will need a two way centre off momentary switch for each point (or series of points if operated as, say, a pair on a crossover). These are often described as (ON) OFF (ON) switches.
If you use an AC supply you only need a single pole switch but you need a couple of [style="color: #ff6600;"]diodes as well, if you use a DC supply you'll need a double pole switch. Typically 18V nominal AC or 12V nominal DC supplies of 10VA or more are O.K. Just try it and see if an existing supply works. If operation is a bit iffy you could try thicker wiring to minimise volt drop as an alternative to a higher voltage supply.
