Hi again Dave,
Ignore the comments I wrote on your picture in post 18. I realized the wires I pointed to are the ends of the wires from your motor block connector not yet soldered. These motor block connector wires need to be soldered to the "motor" pads circled below. Use the pic by Phil P. in post 10 as additional guidance. It shows the order in which the connector wires should be soldered to the four "motor" solder pads.
You can check for correctness by doing the following: Connect the off, lights, or lights and motor control switch to the board and
set it to the lights and motor position. Plug the motor block connector onto the motor block.
Set the interface board for DCC.
Your VOM should now measure no resistance between the ws pin on the motor block and the ws decoder harness pin on the interface board. You should have no resistance between the br pin on the motor block and the br decoder harness pin on the interface board. You should have no resistance between the gr pin on the motor block and the gr decoder harness pin on the interface board. And finally, you should have no resistance between the ge pin on the motor block and the ge decoder harness pin on the interface board.
Next, there should be an open, or high resistance between the br pin and the other three, ws, gr, and ge pins whether measured at the motor block or the decoder harness pins on the interface board. Likewise, there should be an open or high resistance between the ws pin and the other three br, gr, and ge pins.
Finally, you should see motor winding resistance between the gr, and ge pins whether measured at the motor block or the decoder harness pins on the interface board.
Reset the interface board for analog. It should now work with your analog controller.
As an aside, I realize from Phil P.'s pic in post 10 the two pins I've got circled are for connecting the lights, not the decoder harness. I should have looked more carefully.
