Hutch
G Gauge, Raising Peaches, Apricots
On this subject can any one tell me how to get inside a 50080/50081. I'm sure I did it once to fix the terminals but I cannot remember how I did it.
No such thing as "No user servicable components inside"
LGB apparently sourced these from more than one vendor, so IF yours is the same as mine was, there are two single use push-pins on each of the long sides about 1/2 inch from the bottom. I recall removing them was easiest by drilling or chiselling (exacto chisel) off the heads of the pins, pushing the pins through the holes to the inside, then carefully prying the bottom off. Don't remember if I had to remove the knob or not. Replacement pins were purchased at the local ACE Hardware store.
Just looked at the 50081 currently on my auto-reverse track. It has no visible rivets or other access methods. Although I didn't pull the knob, I assume that means the unit is sonic welded or assembled with adhesive.
A verrry large hammer or 20 ton press would be an alternative access method.
I didn't find the failing part on that one, so I recycled it in a batch of scrap metal. Since then, I have been told that the "self resetting" plastic fuse is actually wound INSIDE the transformer.
Use this information at your own risk. It may have hazardous voltages attached.
