Topogardenmike
Wouldnt be without mine. I have some fairly inaccessible sections, caused by limited space not poor design and the track cleaner makes it oh so easy.
Mike
Mike
nicebutdim said:I've changed the leads to the grinding motor so it pulls with the direction of the loco, as others have done here too. This is very easy to do and cures some of the bouncing, but they all do this anyway. Don't put it near wet or damp track, it makes a lovely brown paste that gunges the grinding wheels and cakes the drive wheels and skates.
ge_rik said:nicebutdim said:I've changed the leads to the grinding motor so it pulls with the direction of the loco, as others have done here too. This is very easy to do and cures some of the bouncing, but they all do this anyway. Don't put it near wet or damp track, it makes a lovely brown paste that gunges the grinding wheels and cakes the drive wheels and skates.
Can I just clarify - does this only work with DCC? I imagine under DC, if the leads were reversed then surely the grinding wheels would rotate at the same speed and in the same direction as the traction wheels and hence not do any grinding - or am I missing something?
I have one of these but haven't chipped it as it seems to be a waste of a chip as it never runs when the other stock is out. Would chipping (and reversing the leads) improve its performance? I've heard the grinding motor goes at full pelt when under DCC - is that right?
Rik
funandtrains said:The best cleaning tool I've seen was a scouring pad fitted to a pivoting block attached to a broom pole. The owner could walk it around the track quite quickly without getting a sore back, it works on wet track too and if it is grungy you just rinse it out from time to time.
I don't like the idea of any grinding track cleaner like the LGB loco as they leave marks on the tracks to trap more dirt.
beavercreek said:It is already 'chipped' with an mts decoder.
funandtrains said:The worst much seems to be sap from trees and if you have this problem so need to wash it off.
That's an interesting 'Americanisation' of the TCL cab Tony?littletone said:Mine is (was) one of the new red ones with on-board mts, great bit of kit.
But it too would bounce about the track, as the cleaning wheel are at full speed on mts and it did'nt like going up gradients. So i now only run it, double headed with the Alco.
Rik
Rik
Couldn't agree more, You'll find your own personal preference with it quite quickly, then your rails will always be clean!stevedenver said:simply stated, get one. they are wonderful.
Gizzy said:That's an interesting 'Americanisation' of the TCL cab Tony?littletone said:Mine is (was) one of the new red ones with on-board mts, great bit of kit.
Tell us more....
nicebutdim said:has anyone tried experimenting with a little added weight on the front to try and control the bouncing? Would it adversely affect the wear on the cleaning wheels?
nicebutdim said:Ah, ok, point taken, I shall leave well alone then. As said I'm more than happy with it's performance now, I shall stay satisfied!
