ZingyOrange
J2s said:Blimey, thanks for the replies..
OK ...........
So if I use tap water in York, with a filter, will the boiler last say 20 years with moderate use? By the time I'm 73 It wont matter what the boiler is like, I'll either be up the chimney or dribbling into my Cornflakes.
You may need to descale it one or twice in that time depending on the water quality but it should easily last 20 years. No matter what water you choose the best thing you can do to prevent corrosion is to empty the boiler after a run and store it dry. I have a 20 year old brass boilered Mamod SL1 thats still going strong and has only ever seen soft tap water
