You’d certainly need a steady hand. Incidentally, mine’s in the post to Tamworth.To get back on topic:
The regulator is centre-picture..
In real-life, about 2mm square.
Hi Les,You’d certainly need a steady hand. Incidentally, mine’s in the post to Tamworth.
Les.
That is the 'fun' bit... Not blowing away any of the other teeny-tiny bits, with the re-melt hot-air tool.Looks like you did indeed find the smoke outlet port. Should not be too hard to repair, unless more around it is disturbed.
Didn’t expect it to get there until tomorrow! One up to the Royal Mail.Hi Les,
Thought you might have twigged? - With the burn-mark, in the bottom-left corner of the chip..
That is your Rx65c!
Excellent, impressive .And there it was, gone!
Replaced by something much bigger!
The 'dead' regulator is sitting down on top of the new one, with its 'legs' in the air!
