GAP
G Scale Model Trains, 1:1 Sugar Cane Trains
tramcar trev said:Is this the correct section for this???
More thoughts on Radio control….
I really do have to take more Stillnox, I wake up in the middle of the night with these ideas. This one lets me use 1 transmitter to control 2 trams ( or if you could find a cheap 3 channel all proportional channel Tx then this would work with that as well)
What if I could get 27 MHz RC transmitters and receivers very very cheap? If say I could get a 2 channel brand new 27 MHz transmitter for $16 and a whole pile of receivers with crystals all round to match for $10 each and ESC’s for $8.61 ea…. And given that unless you’re Ross at best I can control 2 trams at once I could set up the receivers so that one of each channel could give me speed control over one tram? There would be a separate Rx on each tram and the ESC would be either on Ch1 or Ch 2.
With me so far? Also remember that all I am after is really control over speed, reversing is manual as is swinging the trolley pole…
So I could control 2 trams that corresponded to either of the 2 channels on the Tx. Each joystick on the TX would have underneath it written the numbers of the trams that channel could control. It would mean that trams would sit in the sidings and would not respond until the Rx was switched on.
Alternately I could at that price buy 6 Tx enough to control 12 trams at 1 per channel.
Now this all appears too simple for me so there must be some reason why it can’t be done. Remember each Rx would have a mating crystal for the Tx; each Rx would be switched on to activate the tram. And yes I would have to supply 6v for the Rx, easily enough via an L7806 regulator….
There is also an RxESC combo available but it’s not as cheap…
Why am I bothering you may ask, I have the keyfob thing running well…. I know I can control 2 trams at once with the key fobs, one in each hand but it’s the button pushing and response time that’s grinding me a bit, with a spring loaded joystick I have a dead man’s handle built in…. I'd use the Deltang unit but by the time I land it here its expensive and you also have to switch between the train your controlling.
But there must be some reason this can’t work because if it did everyone else would be doing it…..
Some of you will get the jist of what I'm blithering about and some of you will be able to answer the question "is this going to work?"
Trev,
I am doing exactly what you want to do using cheap 2.4GHz Hobbyking TX/Rx combos.
In fact I can control 3 locos from one transmitter though 2 of them answer the throttle and direction at the same time so I rarely do that.
If I want an exciting session the 2 locos in opposite directions and use 2 passings sidings to avoid collisions.
If you want more info just give me a yell.
