Do you know that? Or are you assuming that because it hasn't been changed, no one has told them? If they're anything like the company I work for, it doesn't matter how many times they are told something, its ignored every timeA gold star to you both!!
Not sure how no one has ever mentioned it to Occre in 10 years!
All I can say is they said thanks we've not spotted it before, we'll change it and send you a new set of decals. Let's see what arrives...Do you know that? Or are you assuming that because it hasn't been changed, no one has told them? If they're anything like the company I work for, it doesn't matter how many times they are told something, its ignored every time
How many do you need and would you be happy with filament as opposed to resin prints? If so, just covering the postage is fine. If you have access to a printer, the files are in the 3d print section.I like your axle bbearing/pedestal/thingies ! As I have some Apple Tree and Fosmotor setups I would like to experiment - and your bearings look just right. Mine 'for a pint of beer'...... how much is beer in your area?/
I am hoping to try building a motor bogie and remotor one of my 4 wheelers, so would 12 be too much of a pain for you?How many do you need and would you be happy with filament as opposed to resin prints? If so, just covering the postage is fine. If you have access to a printer, the files are in the 3d print section.
These are designed for 31mm wheels, so you may need to pack them up a bit for larger wheels.
Interesting as I have not used the Occre lettering sheets on my LCC conversion, are they actually transfers? I got the impression that they were just prints on quality paper to be glued in place.All I can say is they said thanks we've not spotted it before, we'll change it and send you a new set of decals. Let's see what arrives...
Yes, they are just stickers on glossy paper. They do look very good though, but you need a little bit of effort to hide the edges sometimes.Interesting as I have not used the Occre lettering sheets on my LCC conversion, are they actually transfers? I got the impression that they were just prints on quality paper to be glued in place.
Well I reckon you succeeded with that little bit of work.Yes, they are just stickers on glossy paper. They do look very good though, but you need a little bit of effort to hide the edges sometimes.
That's very good service indeed. I raised an issue with a supplier about their lettering and they acknowledged it was incorrect and said they could correct it if I paid for the new artwork. Suffice to say I sourced an alternative supplier.Look what turned up today!
The corrected lettering for the tram.
Top service from Occre. How many other manufacturers would do this? Not very many I would wager..View attachment 283079View attachment 283078
Looking at the photos it looks like all the coloured panels are stick on, so is external painting kept to a minimumLook what turned up today!
Correct, but you need to paint all visible edges and sand and varnish the whole tram to ensure the stickers stick!Looking at the photos it looks like all the coloured panels are stick on, so is external painting kept to a minimum![]()
