MP3 Player
Mike Bett
14 Apr 2010
201
3
Fallbrook, California.
United-States
I am looking for something to play the bells and singing in the Church on my layout.
It will be powered by my layout lighting circuits, and will need to have a speaker.
Any recommendations, don’t need any swish expensive kit!
DickyC
(BZB Mountain Railway)
26 Jul 2017
326
52
47
Rural Shropshire
check out the vid in this product, the basic sound card has a church option. if you contact Marius at MD he will let you know of a US dealer or send it out himself.
you can change the subtitles in a YT video to english.
ge_rik
1,247
Cheshire
www.riksrailway.blogspot.com
I've used a couple of these modules - self contained and cheap with the option to loop the sound so it plays continuously
This is as advertised on AliExpress but you can get them in the UK for around £12 from eBay
Here's one way I've used mine (with a video so you can see what it sounds like)
Rik
ge_rik
1,247
Cheshire
Or here's another alternative. About the same price but a neater package and plays sounds from a micro SD card.
Rik
PS - An added bonus is a built-in FM radio so you could listen to Radio 4 (or whatever) while you're gardening.
Mike Bett
14 Apr 2010
201
3
United-States
Thanks guys.
What I am looking for is something that will be powered by the building lighting circuit, so that when I switch on the lights in the buildings the sounds kick in and play. No buttons to press and no charging needed.
I have looked at the cubes, great price, but hassle with charging and switching on and off.
Any further suggestions much appreciated.
Degauss
9 Jun 2017
81
13
74
Australia
Thanks guys.
How much electric do want to do?
You can used a DY-SV8F or DY-SV5W module. Requires 5v dc in, has 5W output for speaker and 8 select lines.
The DY-SV8F has 4M memory onboard which to store music on via the USB socket. The DY-SV5W uses a SD card for holding music.
If a select line is connected to ground, then that track plays continuously when power is applied.
Available from amazon/eBay/AliExpress just search for DY-SV8F or DY-SV5W. [https://www.amazon.com/dp/B0CP79C4WC]
Will hold more than one track. When sick of the same music, flip a switch (8 position rotary would be good) and will play something different.
Mike Bett
14 Apr 2010
201
3
United-States
Thanks Degauss. Sounds as if this will do the trick. I can give it 5V DC.
Madman
3,003
Pennsylvania, USA
I use ITTC sound modules. The cost is $39.95 per module. George, the maker of these will happily make a custom module at no additional cost.
Here's a link to his site;
3,553
Allegedly, he will no longer supply to the UK..
Madman
3,003
Pennsylvania, USA
Is this device as simple as it appears ? How do you load sounds to it ? Where does the SD card go ?
