ntpntpntp
If you want to avoid the complexities of reversing modules or change-over switches then that crossover has to go. You've got a dead short right now - if you pull apart the two points in the crossover you'll remove the short for now until you decide what to with these points. Unfortunately even fitting isolating joiners between the two points won't be enough, you'll still get a short when a loco runs through the crossover.
[edit]
You have another two reverse-loop configurations at the bottom of your diagram, they also need some isolating joiners and change-over mechanism
[/edit]
[edit]
[/edit]
