Rhinochugger
Retired Oik
Recommendation from C2B - Blow down the boiler
Can you explain how that is done, Max?
OK, got it.Depends on the loco design - Usually near and under the vertical steam oil reservoir there is a tap, slowly undo that a couple of turns so steam can escape. I think you have to have the regulator open to do this. Unscrew it completely, once the boiler has blown down leaving no pressure, and you can drain any remaining condensate and/or unused or emulsified steam oil.
On some locos, like my Accucraft Joan, there is a separate tap on the opposite side to the steam oil reservoir, again on the underside of the chassis. Undo that and you can release the steam pressure that remains in the boiler alone. You do not have to have the regulator open for this one.
Both of these are methods to "blow down" the boiler. Handy if you want to do a refill of the boiler without waiting for it all to cool down and do not have a Goodall valve fitted or a water pump connected to the boiler. Strangely my Lew has neither fitting mentioned above. You have to syringe out any condensate or emulsified oil from the reservoir. Max
Edit - The taps/valves I'm referring to are termed check (water level) or drain (oil reservoir) valves. The Edrig the OP Claes owns has both fitted. Take a look at the Accucraft site, all the UK loco specs are there as are the US ones on that site.
Draining the lubricator of oil has always puzzled me, and is not something I have ever done. Drain water yes, but oil no. Some people describe the emulsified oil left at the end of a run as "muck" or similar, but it is only a mixture of oil and water caused by emulsification. It is exactly this emulsified oil that the loco uses for lubrication - not clear or "clean" oil - and the lubricator makes it as the steam supply passes through.
We can discuss the pros and cons of lighting the gas by putting a flame to the top of the chimney next if you like...
Is the correct answer. Yes, the gas is heavier than air so with the gas valve open and no flame the loco ends up sitting in an invisible puddle of unburnt gas. And when a flame arrives ... Woomph!Now, I've never tried lighting at the top of the chimney - would it be a waste of gas? As the gas is heavier than air, why would it want to go up the chimney. I open the smokebox door, light the gas and watch it strike back, then close the door and wait for the kettle to boil ...............![]()
Many thanks for your long answer Max, what you write may be very helpful, because this is my first real live steam loco. I like the Annie I bought from you earlier very much. I have put Swedish signs on her so now she looks lika a big Swedish Three feet narrow g locomotive. Maybe I will pay a visit to my very experienced local Marklin dealer here in Town who also sells several live steam I gauge and G scale. and LGB and Bachmann locos, cars and tracks.I am not sure what prior experience you have with gas fired live steam locos Claes. However, there are a few basics when lighting up to follow, this is not a exhaustive complete list but areas I have found helpful to follow, particularly with Accucraft's products -
Make sure you have filled the steam oil reservoir, gas tank and boiler and draw off 40 ml from a fully filled boiler to allow space for steam to form. OK, those are obvious onesDon't forget to drain the steam oil reservoir of water and old oil before filling.
If you still have problems with filling the gas tank, with the correct adaptor, try pushing down on the centre pin on the filler valve a few times. If that does no fix the problem then, as Paul suggested, you may need a new filler valve that can be obtained from either of the suppliers mentioned so far. Other suppliers are available, there is a list on the Accucraft UK site.
Allow a few minutes for the gas in a freshly filled tank to "settle" before lighting up. The spluttering you may experience when trying to light up is caused by the gas remaining in its liquid form and being fed direct to the jet. This is where Rhino's tip can help too - the gas tank is next to the boiler and as they both warm up it helps the liquid butane in the tank turn into a gas.
Check that the gas is flowing to the gas jet freely. Blocked jets are not uncommon - but only try to clear with a blast of gas from the "pointed" end or immerse the jet in lacquer thinners to clean. Never clean the jet with a pin or wire, you will ruin it. It's a good idea to replace the standard gas jet fitment from the factory with a better made one - re' my comment above about buying bits from C2B.
Put a small rolled up piece of blotting paper in the jet - can help to catch any debris before it blocks the jet.
Blocked gas jets can be caused by a number of things - debris, like solder flux, left over from the manufacturing process (Accucraft did a have a problem with this a few years ago), age and level of past use (clean as suggested or replace), debris in butane gas canisters (that's why I store mine upside down and give a quick blast before attaching to the gas tank - think it though)
Make sure that the gas jet has some PTFE tape on its threads to ensure no leaks when it is attached to its holder.
With a 2nd hand loco it is an idea to wipe the O-ring on the gas flow regulator (and steam regulator) with a little steam oil to improve the seal and its operation.
The brass ring on the burner acts just like a car's choke. Use it to half cover the holes on the burner when lighting up, it enrichens the fuel/air mixture. Get yourself a nut driver of the right size, with a long shaft, so you can easily adjust and reposition this device.
Accucraft locos are prone to requiring multiple attempts to light and maintain the flame in the burner. Try leaving the smoke box door open for a couple of minutes after initial lighting to help ensure the burner does not extinguish itself.
All the best, I'm sure with this loco you will be smitten by live steam operation and it will be the first of many. Max
Claes,I use an ordinary gaslighter can with a short plastic adapter or nipple, that come with it together with others who don't fit. Shall I buy myself another adapter? I have seen some longer ones in brass on the net but they seem to be intended for canisters for other makes such as Roundhouse?
