James Day
Guano Corner Rly - Runs weekly - Guano permitting
		Dear All,
New Bachmann TTE items are arriving in shops at present. Last week the new Emily loco arrived with the SC Ruffey private owner wagon (see Emily Thread) and today I received the the Thomas series goods brake.
It is a very good looking rendition of a BR Standard Type 20T Van, although I am still mystified by the NW letters is carries. The railings are all moulded on, but picked out in white. Running boards are moulded on the chassis, as is the brake gear, but unlike most other Thomas items these are noticably not in alignment with the wheel treads.
The body and roof is a one piece moulding, with slide in glazed baulkeads. This is clipped and screwed to a one piece floor that is held to the chassis by two screws at each end. The level of detail looks good, but the windows in the duckets are moulded solid with the body.
The vehicle is yet another one with an incredibly long rigid wheelbase. The wheels are smaller than all other TTE goods items and are spoked. The look the same size as standard LGB and Playmobil wheels, so one option for lighting is to use Roller Bearing wheels instead on the Carbon pick ups that I have used on Annie/Clarabel and the Emily Coaches.
The bearings are a new design too, they are plastic journals that clip in from below, and appear much quieter that the metal trunnions used on earlier TTE stock and even the more recent versions with plastic bushes fitted.
The couplings supplied were the large D type as used on James/Emily and the Emily coaches. These are rigid, as is usual with this series. and can be fitted at two heights, although the box insert will still need carving a little if the item is to be put back in the packaging once the LGB/Playmobil height adaptors are fitted. It appears to be able to cope with 2'Radius curves, although there is lots of drag, owing to the long rigid wheelbase. I am unable to try it on reverse curves at present, but my guess is that it would not like them that much! Like the TTE coaches, it would be much better if the couplings pivotted.
Thi SC Ruffey wagon was described in the Emily thread. Both items shown have now been fitted with genuine LGB couplings.
Mine came from Gaugemaster and cost around £45, plus £5 P&P. Excellent value as all with all this range.
James
James
		 (usually it would be just one lamp put on the rear as appropriate as they were separate items)
