It's actually perfect for this Martin. The brick base has a floor moulded in, but holes could easily be drilled in it to pass any wires through and it would then keep the electrical kit off the damp ground. The van body is hollow and would simply fit over the top.Martino said:Here's a stupid question. Is the van body solid or empty?
I have a need for a line side hut or grounded body, but need to put some electronics inside, out of the weather....
yb281 said:It's actually perfect for this Martin. The brick base has a floor moulded in, but holes could easily be drilled in it to pass any wires through and it would then keep the electrical kit off the damp ground. The van body is hollow and would simply fit over the top.Martino said:Here's a stupid question. Is the van body solid or empty?
Bob, if you send Rob a PM he'll sort it all for you (that's what I did). His website is currently undergoing a makeover I think.
Any time mate.bobg said:Yeah, I've done that Mel.................then I'm heading your way for some weathering lessons.![]()
Got to chip in here, it was me who asked for couplings!RobB said:...the new bits will be poping up during this week, couplings are there now (asked for by you).
Thanks Rob.RobB said:Then I'm ready to take your order![]()
Doug said:Rob - I'll be at the 16mm show at the end of the month. Can i pick up a well wagon, wiggly van and grounded wiggly van body
I was looking at some of the loads such as the scratchbuilt(?) tank turrets etc. :-RobB said:Hi,
I've only had one reply so far to this comp via my Email rdbush@ntlworld.com
The comp is for a LOAD, not what you have done to the wagon, so your still OK![]()
Doug, what gauge are you wanting your wagons in?
Rob.
