new to g scale
I forgot to mention pneumatics for points, really low maintenance all of my line points (switches) have been powered by Air since I started using it back in around 2000. I have used Del Air, Easy Air (both now unavailable) and even have some Sunset Valley on my line though I find the Levers a little in the small size they do make a nice neat panel. All of my Lines go through modest sized Electrical Trunking, I spray it Grey to match in better on the line some I have even scored with a saw to look like Railway Cable Trunking runs. This for you will have the same benefits for me, easy access for revisions and perhaps some protection against critters. I have had ants nests in the trunking with no ill effects. The trunking is also useful for Electric Cable runs as I used to run DCC, but in your case with battery any such runs may just be for Building Lighting.
As for those water courses, embrace them use large rocks where they go to make like a River and run bridges over for the Track. I have made fake water courses on my line using Cement Based on top of Butyl Liner with the rocks bedded into the cement, so long as you preserve the natural route and depth of the water this should work well for you.
Thanks again. I've looked at Sunset Valley, including a couple of trips to their booth at last year's Portland show. Very interesting. Your idea of distributing the air lines (and some DCC lines) in electrical trunking is a great add on.
In my case the water courses are only 'active' water courses after a big rain and then only for minutes. I just need to plan for them. Maybe a bit of cement, liners, bridges ... they should be some of the most visually interesting parts of the railroad if I do it well.
Welcome to the forum cvcanada. Having gone through the electrically driven - manual - air powered cycle of operating my points/switches, I can thoroughly recommend using a pneumatic system for these. I too use the readily available SVRR system, as it is now distributed in the UK ( the guy who makes it is a Brit' expat' !). The SVRR system is based on modified standard mainstream Clippard pneumatic components. It's ideal if you live in areas where climate extremes, water (precipitation) and heat, may affect the reliability of electrically driven systems and require excessive maintenance as a result. I have adapted their turnout motors to operate my semaphore signals. I power mine from a small airbrush compressor with a 3 ltr reservoir tank.
Looks like you have a major project on the go there. What do you plan to run ? Max
Thanks for the welcome. So far the forum has been very welcoming.
I clearly need to look at Sunset Valley again.
My plan is to run steam (DCC steam not live steam) locomotive dating from 1880 to 1940 with mixed passenger and freight service. However, a Christmas Train of some sort will probably violate my time period. It might still be a steam locomotive, but year is it when you stick a picture of Santa Claus on the side?
