Greg Elmassian
Guest
I do not agree that resetting by writing to a CV is bad, in most cases it's the only way.
(when you have a chance I would love to read the passage you are referring to)
When in service mode, only low current is used, so #1 cannot be true IF you are running service mode. (JMRI should indicate if it cannot read, i.e. go into service mode)
If you are not in service mode you CANNOT read back from the decoder. I'm still not convinced you are in service mode.
I'm telling you to reset the decoder, sometimes everything is right but the decoder is locked up. Also there's very few ways that the decoder would not have SOME output to the motor.
Yes, another theory could be that you are in service mode, but then the functions could not be operated, and you stated that they work.
Something is still fishy with the "story"... I can give you step by step to debug this, but I don't want to be "fighting" statements like resetting by CV is not recommended, that statement by itself is just not true, so it must be out of context or not properly understood or not quoted accurately.
My recommendations would be:
1. verify service mode
2. write a CV and then read it back to guarantee you are actually in service mode.
3. reset the decoder
4. then verify the operation of the motor, or debug the electrical problem.
