To overcome my issues and understand my traction problems I started a thread on
Bogie Construction, which provided lots of ideas guidance and advice, with the two main potential issues to traction being Sprung Compensations on the axles and Drive to both wheels.  To enable these I decided to build a bogie chassis with inside frame, which would later have dummy bogie outer frames.
The bogie frame made with 0.080" brass sheet, commercial frame spacers, and Horn Bl;ocks with Sprung Compensation, and Delrin chain drive.  It has taken some time due to domestic duties, and waiting for parts, but I assembled it yesterday, and the bogie ran, so temporally attaching the Streetcar I gave it a run including my 1:24 gradient, and there was NO wheel slip.  Of course other issues that I suspected would manifest themselves, did, but these were poor judgement calls on my part and are easy fixes, the good point is it worked:
The original bogies that I wish to emulate in looks, and a rough drawing:
The assembled bogie showing the gearbox and drive, the compensated horn blocks just visible at the back
A view from underneath showing the compensation and my messy (but effective) soldering:
Wheels removed to chemically blacked the frames to make them less visible through the dummy frames
The dummy frames are almost complete however due to the bogie pivot being behind the motor, I am in the process of devising an assemble method which will allow easy(ish) disassembly.
