Andrew Smith
Hi, What's the best way to cut flexi track, are specific tools required?
Andrew
Andrew
I should have added where the track is in positionI use a Dremel, and the quick release disks and never had one shatter, the small ones, yes. Also the flexi extension allows the body to get closer to the track.
Cutting track before fitting, a good vice and a 32 tpi hacksaw.I found a Junior Hacksaw with a new blade works well. However it is also worthwhile to have some preasure on the rail to help. I have a short length of 2x1” timber with 45mm rail groves cut in to hold things steady when pressed down during cutting.
I'm not demeaning the suggestion, but when i used a saw, even a small razor saw, it seemed to put undue stress on the "spikes", the plastic parts that hold the rail to the ties.
This has been my experience (also it takes a lot longer ha ha!)
greg
I was just about to say that - the normal Dremel cutting tool doesn't have a large enough diameter to get a nice cut.Notice the new cutoff disks are large in diameter, so you can cut the rail by lying the tool on the track.. you can also get an even thinner extension to make this easier:
Hi Andrew, I use a dremmel with a cutting disk for the rail and sleepers. Just need to file the rail ends after.Hi, What's the best way to cut flexi track, are specific tools required?
Andrew
I have a twin pack, and I find then quite long lasting and very durable.I could be tempted Dremel SC690 Cutting Accessory Set 10 Pcs - Screwfix
However, these types of disc wear down quickly. There are better prices by Screwfix are just down the road. I don't do Prime. Max
