Hi Everybody,
I thought I'd finally post some pictures and comments about the GR I've been working on.
First, a couple of shots of the initial loop. I took the advice of others and put down this track in 2014 just to have something outside on which to run a few trains. It gave a start and incentive to continue.
Outdoor electrical boxes are attached to the low wall on the left. I was wise enough to run two underground conduits from the house but not smart enough to use a larger size! Both are 1/2". If I had a "do over" I'd go with 1" minimum for the low voltage conduit supplying RR power. It would give room for a lot more wires. For now, I have one 4-conductor 12AWG stranded wire line in the low voltage conduit. Two of the conductors are used for power to the rails. The second pair are for a future booster.
The wall in the background of the third photo is the beginning of my "mountain" and waterfall/river. The second electrical conduit is for 110V power for the waterfall pump. This is where things stood by the end of Fall 2015.
I finally settled on the type and maker of the water feature in Spring 2016 and the pieces arrived in late June. Summer and Fall 2016 were spent installing the waterfall.
The next two shots show upper filter/waterfall unit. The space between the two walls is for a tunnel through the mountain. Also visible is the trench for the 110V conduit for pump. This conduit was re-directed to move the outlet closer to the pump. (Yes, a permit was pulled and the electrical work was inspected and approved by the city.)
The walls are made of concrete block wall stones that are available here in the States. They make construction easy. The key to using the concrete blocks is to make sure a good compacted stone base at least 6 inches deep is in place beneath the first course and then very carefully leveling the first course.
The next photos show the strainer unit and pump vault being buried. I added the 55 gal poly drum for additional water capacity. The intent was that all the water in system could be contained underground when the pump was shut off. More about that later!
The second photo shows the pump vault plumbed to the filter/waterfall unit. I've also run a conduit with goosenecks on both ends from next to the 110V outlet to the pump vault. The pump's power cord fits through the conduit with its plug attached. This makes it easy to remove the pump for winter storage. The smaller gauge black hose in the first picture is an automatic water make-up line yet to be run.
The next four shots show the watercourse being dug, and finally the EPDM liner and rocks - almost 6 cubic yards of rocks - in place.
This is where the RR was at the end of the 2016 construction season.
2017 pics yet to come.
Phil S.
Phil S.
