Deutsche Reichsbahn said:Common problems:
- Windows fall out of the cab
- Cables come loose from motor block
- Wobbly axles
- Derailments in R1 curves & switches
Go on Sandy, you know "you're worth it".DVRR said:I really do want a croc, but all these comments just reconfirm that it will be an LGB one, may have to wait a bit longer, but as usual it will be worth it. P & S Hobbies have 3 limited edition Blue versions, factory fitted sound and chip, slight drawback is £1000 price tag. He also has the brown and green versions in stock somewhat cheaper.
The difference between them is huge. But if you're following rule 8, no problem ofcDVRR said:I really do want a croc, but all these comments just reconfirm that it will be an LGB one,
Its got me pondering now on what to buy piko or lgb but as ya say £1000 against pikos cheeper version and you can purchase 3 piko silverling coachs with changeDVRR said:I really do want a croc, but all these comments just reconfirm that it will be an LGB one, may have to wait a bit longer, but as usual it will be worth it. P & S Hobbies have 3 limited edition Blue versions, factory fitted sound and chip, slight drawback is £1000 price tag. He also has the brown and green versions in stock somewhat cheaper.
That £1000 is for the limited edition one..kev peel said:lgb but as ya say £1000 against pikos cheeper versionDVRR said:I really do want a croc, but all these comments just reconfirm that it will be an LGB one, may have to wait a bit longer, but as usual it will be worth it. P & S Hobbies have 3 limited edition Blue versions, factory fitted sound and chip, slight drawback is £1000 price tag. He also has the brown and green versions in stock somewhat cheaper.
DVRR said:I know I am Adrian.... but its a question of the money.....
