see below message,
I have A blue V60 loco, and it has been underway to and from piko more than it has been on my shelf, constant contact problems etc etc It should come back now soon, I have had enough, so what I will do is take out all original wiring and electronics and built in a massoth xxl decoder,
I think it is the best thing you can do with the croc as well. But on the other hand you pay a lot of money for a model that is not working as it should. and for the same money you can get a lgb croc with decoder.
on the first production series of the croc it could happen that the pivoting axle derails as it will touch the under carriage when driving thru R1 curves.
Above he engine block there are two wires of rigged material, it could happen that the tight loops and rigid material in combination with the tubing can cause the connectors to lift causing bad contact and limited or no driving at all?
See picture below.
Quick translation from an article in a newsletter from grootspoor
rgds niels
See picture below.
rgds niels
