Piko General Electric 25T Switcher.
casey jones snr
20 Apr 2010
12,007
7,525
73
Charnwood Forest Railway. Rothley. Leics.
England
For the first time in eight years the CFR has received a new battery powered radio controlled locomotive by PIKO:-
The locomotive is powered by 6 AAA batteries. I have used 1100ma batteries and I hope to get at least four hours run time out of them. The transmitter is similar to a car key fob.
viaEstrecha
298
Bedfordshire
United-Kingdom
Excellent and in an attractive livery. When my little track cleaning one ran on 6xrechargeables, I certainly got 3-4 hours. Less now, with a NiMH battery pack but that has to cope with sound, lights and dancing girls too. OK, maybe not the girls, just couple of surly crew.
Hal Farsed
D.P. Gumby.
7 Apr 2014
2,240
1,461
Staffordshire, England.
Paul, I have looked at these. If you get a minute, would you mind dropping a ruler over its main dimensions?
James M
5 Feb 2017
113
51
66
Essex
I have two of these locos. Would definitely recommend them!
James M
5 Feb 2017
113
51
66
Essex
Here’s one of mine.
5,010
76
This is my heavily modified (in terms of power and RC), Paul I think you must have 2 of the little beasts. Is it really 8 years since your last Roundhouse Battery Diesel?
Reactions: 1 users
casey jones snr
20 Apr 2010
12,007
7,525
73
England
No Jon, I have purchased plenty of Roundhouse RC Locomotives in the last 8 years. The Piko locomotive was my first purchase of a plastic made item in over 8 years and yes I now have two of them. My next purchase will be the track cleaning locomotive.
I rather like the weathering and hard working locomotive that you have.
Reactions: 1 users
casey jones snr
20 Apr 2010
12,007
7,525
73
England
The Piko GE 25T Switcher is continuing to surprise me and pass all expectations. Today I hooked up 24 wagons and a brake van behind the locomotive. It was able to haul the entire consist without any problems:-
Madman
3,003
Pennsylvania, USA
I'm impressed that the Piko loco is able to haul that many wagons. How steep are the grades, if any ?
3,553
Very impressive!
Piko's answer to the Stainz, which we all know, can pull well-beyond what the prototype would ever have been called on to do.
The Piko Lok, just needs to prove its longevity, and resilience..
If anyone can put some miles on one, Paul and the CFR can! :nod::nerd:
casey jones snr
20 Apr 2010
12,007
7,525
73
England
Dan, most of the grades are quite gentle. However the old rack line is very steep and it can propel 7 wagons up to the summit.
I have a picture of the switcher propelling coaches up the loco shed incline:-
5,010
76
Mine pretty well does all I ask of it, on conversion to get more batteries in I removed the weight but have replaced that with lead sheet behind the wheels as shown in my conversion post. Load wise it is sometimes used to populate Silberhutte with wagons from the shed and as many as 10 or so LGB full sized wagons managed with ease. Not a simple task as some are on the R1 curve in the shed though the route is pretty level.
casey jones snr
20 Apr 2010
12,007
7,525
73
England
Mina pretty well does all I ask of it, on conversion to get more batteries in I removed the weight but have replaced that with lead sheet behind the wheels as shown in my conversion post. Load wise it is sometimes used to populate Silberhutte with wagons from the shed and as many as 10 or so LGB full sized wagons managed with ease. Not a simple task as some are on the R1 curve in the shed though the route is pretty level.
Jon, a very versatile locomotive. I am going to invest in the track cleaning locomotive.
3,553
Paul, it does 'polish' the railhead a little, but would take some-time to do a meaningful job, on heavily tarnished rail. - It usesSlide clipboard items to delete the springs on the skates, to keep the cleaning pads in contact with the rails, so not a great deal of force is applied.
Revok
19 Jun 2018
114
133
68
West Sussex, UK
I have been using the track cleaning loco for almost 3 years, and I like it a lot.
As previously mentioned, it doesn't have much effect on really dirty track, but I have found it does a good job at maintaining the rails in good condition once they have had the worst of the tarnish removed by the traditional scotchbrite mop method. To give some idea of scale, before loco I'd need to manually clean track every day before running. Since loco I think roughly once a week some area might need a bit of a rub.
With 900mAh NiMh batteries I originally got just over 2hours continuous running. I use it just about every day the weather is dry enough to be out in the garden, and after 3 years I'm still getting 2 hours, a little less if I'm pulling something behind it.
Cleaning pads need replacing, and I'd guess it varies wildly depending on conditions, but for what its worth I renew approx every 3 months.
Here's mine on duty.
casey jones snr
20 Apr 2010
12,007
7,525
73
England
Phil, the track at the CFR is not powered. The idea is to use the track cleaner to remove oil deposited by the live steam locomotives.
James M
5 Feb 2017
113
51
66
Essex
Here’s my other 25t. I rather like the one in Union Pacific livery too.
Reactions: 1 users
casey jones snr
20 Apr 2010
12,007
7,525
73
England
Very nice livery James. However I prefer the green liveried one shown in the picture posted by Revok.
